Adaptateur très compact. Fonctionne parfaitement depuis plus d'un an.
This adapter works perfectly with ALLO BOSS DAC PCM5122 32Bit / 384kHz with 2 clocks Master Clock I2S
This adapter Micro USB female to male USB-C allows you to connect to your devices using the USB-C connector.
It is equipped with the standard OTG (On The Go) which does not need a master machine (computer). It is therefore possible to use it as a direct connection without needing a master machine such as a computer (provided both devices are OTG compliants)
Suitable for audio use on recent devices, this adapter is a good solution to connect to your DACs and recent interfaces like the Boss Allo DAC v1.2. This will use this adapter to connect directly to a smartphone or any device capable of storing and OTG-compatible digital audio.
Type | Adapter |
Input | Micro USB |
Output | USB-C |
OTG standard | Yes |
Dimensions | 24 x 9.8 x 5 mm |
Connectic | Male & Female |
Connector | Micro USB |
Connector | USB-C |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
