I'm writing this, because this is the second DDHIFI item that quit working after some months of use. The lightning part will come loose from its socket, very disappointed of DDHIFI build quality, the sound was great though.
The USB-C to Lightning DD MFi09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and therefore signal transmission. Thus, its conductors are made of pure silver Litz wire for the data part and OFC copper for the power supply.
Male USB-C Cable Silver / OFC Copper 10cm
The parallel structure of the cable benefits from a double shielding to protect the data and power sections independently. The signal is thus protected from interference and the transmission is perfectly stable.
Product type | USB-C / Lightning Cable |
Connectors | 1x Male USB-C 1x Male Lightning |
Length | 10cm |
Cable conductors material | Data: Pure silver Litz wire Power: OFC Copper Litz wire |
Cabe conductors section | Data: 0.109mm² (26.7AWG) Power: 0.141mm² (25.6AWG) |
Cable conductors shielding | Data: OFC Copper Litz wire + Silver plated LCOFC Litz wire Power: Silver plated LCOFC Litz wire |
Internal insulation | High precision chemical foam PE |
Outer insulation | Transparent PVC SoftFlex |
OTG | No |
Weight | 13g |
Color | Gray / Silver |
Length (m) | 0.1 |
Shielding | Yes |
Section (mm²) | 0.109 |
Section (mm²) | 0.14 |
Connector | Lightning |
Connector | USB-C |
Conductors material (Cable) | Silver |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 1.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Martin A.
