FIIO LD LT1 Male Lightning to Male USB-B Cable Copper Monocrystalline Double Shielding Gold Plated 0.5m
With LD LT1, FiiO presents a Lightning to USB-B cable using high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. The LD LT1 is perfect for connecting a smartphone, tablet or computer with lightning port to a DAC equipped with USB-B connectivity, such as the FiiO K5 Pro or FiiO K9 Pro, for example.
Reference : 18009
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 09-07-2025.
FiiO LD LT1
FIIO LD LT1 Male Lightning to Male USB-B Cable Copper Monocrystalline Double Shield Gold Plated 0.5m
With LD LT1, FiiO presents a Lightning to USB-B cable using high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. This cable ensures interference-free data transmission and limits jitter. Multiple insulations cover the conductors to guarantee a high level of shielding. The cable is then covered with a PVC sheath and a second, braided, high-quality nylon sheath. The body of the connectors is made of an aluminum alloy for robustness and durability. The LD LT1 is perfect for connecting a smartphone, tablet or computer with lightning port to a DAC equipped with USB-B connectivity, such as the FiiO K5 Pro or FiiO K9 Pro, for example.
The cable does not support devices requiring more than 200mA current and is not suitable for recharging the battery of connected devices.
Quality structure
FiiO's LD LT1 Lightning/USB cable has a structure worthy of much more expensive cables, with copper conductors, reinforcing wires and double shielding with aluminium foil and tinned copper braid.
Product typeLightning / USB cable
Connectors1* Male Lightning
1* Male USB-B
Length0.5m
Cable conductors materialHigh-purity copper
Tinned copper
ShieldingAluminum foil
Tinned copper braid
Cable diameterØ5mm
SheathPVC
Braided nylon
Connectors shell materialAluminum alloy
Connectors contacts materialCopper alloy
Connectors contacts platingGold
Max. current200mA
ColorCable: Black
Connectors: Gray and black
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-B
ConnectorLightning
With LD LT1, FiiO presents a Lightning to USB-B cable using high-purity copper conductors for pure, stable...
