Hub USB / HDMI / SD / Jack
The Ikko ITX01 is a versatile hub, offering a wide range of connectivity to connect many devices. There are three USB-A 3.2 ports, two USB-C 3.2 ports, one of which benefits from the USB-PD 100W fast charging technology, an HDMI 2.0 4K 60Hz output, an SD slot and a Micro SD slot as well as two audio outputs in Jack 3.5mm and Jack 4.4mm formats. The ITX01 also has an audio decoding capacity thanks to its SNC8600 DAC and even offers three operating modes: game, movie or music.
Product type | Hub USB / HDMI / SD |
Connectivity | 1x USB-C PD 100W 1x USB-C 3.2 (Data) 1x HDMI 2.0 output (4K 60Hz) 3x USB-A 3.2 1x SD slot 1x Micro SD slot 1x Jack 3.5mm output 1x Jack 4.4mm output |
DAC chip | SNC 8600 |
SNR | 100dB |
THD | 0.01% |
Max output level | 64mW |
Supported sampling rates | PCM up to 192kHz |
Compatibility | Android, iOS, Mac OS, Windows 10 / 11, PS5, Nintendo Switch |
Color | Gray |
Package | 1x Ikko ITX01 1x Transport bag |
Length (m) | N/A |
Shielding | NC |
Section (mm²) | N/A |
Connector | USB-C |
Connector | HDMI |
Connector | Micro SD |
Connector | USB-A |
Conductors material (Cable) | N/A |
Conductors Plating (Cable) | NC |
