Adapter Female HDMI 2.1 to Male USB-C 8K HDR 20cm
This adapter features a female HDMI connector and a male USB-C connector. Its careful design and integrated Synaptics VMM7100 chip enable it to support video streams up to 8K 60Hz, 4K 120/144Hz and 2K 240Hz. It is also compatible with the HDR standard.
Reference : 18466
34,90 €tax incl.
29,08 € tax excl.
Adaptateur HDMI / USB-C
HDMI femelle vers USB-C mâle 8K HDR 20cm
Adaptateur HDMI femelle vers USB-C mâle 8K HDR 20cm
This adapter features a female HDMI connector and a male USB-C connector. Its careful design and integrated Synaptics VMM7100 chip enable it to support video streams up to 8K 60Hz, 4K 120/144Hz and 2K 240Hz. It is also compatible with the HDR standard. The cable uses tinned copper conductors with a 30AWG cross-section and triple shielding, ensuring excellent conductivity and effectively limiting interference. The connectors are gold-plated to maintain good conductivity while offering perfect resistance to oxidation. This adapter is ideal for use with devices that only have a USB-C format video input or output, in order to convert it to the more common HDMI format.
Product typeHDMI / USB-C adapter
Supported resolutions8K 60Hz
4K 120/144Hz
2K 240Hz
HDR support
Length20cm
Conductors materialTinned copper
Conductors section30AWG
Cable shieldingTriple
Outer braided sheath
Connectors contacts platingGold
Connectors shell materialMetal
Length (m)0.2
Section (mm²)0.05
This adapter features a female HDMI connector and a male USB-C connector. Its careful design and integrated Synaptics VMM7100 chip enable it to...
