ORIGINAL AUDIO OPA-Q1.1 Phono Preamplifier MM/MC RIAA Non-Feedback ADC CS8604 24bit 96kHz
Original Audio proposes with the OPA-Q1.1 an RIAA phono preamplifier with an original design, displaying a surprising cylindrical format, carved from a massive aluminum block. Its performances are not however in retreat, this one offering a beautiful musicality. Its circuits use a double field effect tube as well as an AOP for the MM/MC amplification section and its RIAA curve is of Non-Feedback type.
By buying this product you get 42 loyalty points
Reference : 16337
429,00 €tax incl.
357,50 € tax excl.
Original Audio OPA-Q1.1
Original Audio Préamplificateur Phono MM/MC RIAA Non-Feedback
The amplification stage of the OPA-Q1.1 is also neat, with the use of a Z11 Iron Core transformer specially designed for this model.
For its connectivity, the OPA-Q1.1 provides both a classic connectivity of course, with an input and an output in stereo RCA format. However, it also offers a Toslink optical digital output, associated with a CS8604 ADC (analog to digital converter) supporting sampling rates up to PCM 24bit 96kHz.
Product typeMM/MC Phono preamplifier
Input1x Stereo RCA
Outputs1x Stereo RCA
1x Optical Toslink
ADC ChipCS8604
Input impedanceMM : 51kΩ
MC : 100Ω
Voltage gain (1kHz)MM : 40dB
MC : 60dB
SNRMM : 85dB
MC : 78dB
RIAA Bandwidth20Hz-20kHz, 0.25dB
THD0.008% (1kHz)
Output sampling rates (Optical)PCM up to 24bit 96kHz
Power supply220V 50Hz
Dimensions120 x 995 x 315mm
Weight2kg
ColorSilver and black
BodyAluminium / Plastic
Operating temperature0°C / +40°C
OutputOptical Toslink
ClassN/A
Remote ControlN/A
Original Audio proposes with the OPA-Q1.1 an RIAA phono preamplifier with an original design, displaying a surprising cylindrical format, carved...
