AMPAPA A1 Tubes MM Phono Preamplifier
The Ampapa A1 is a phono preamplifier specially designed for compatibility with MM cells, based on the use of two JAN5654 tubes for a warm, vintage sound, no less clear and precise.
Reference : 20725
124,00 €tax incl.
103,33 € tax excl.
Shipping date: 26-06-2025.
AMPAPA A1 Tubes MM Phono Preamplifier JAN5654
AMPAPA A1 picture
The Ampapa A1 is a phono preamplifier specially designed for compatibility with MM cells, based on the use of two JAN5654 tubes for a warm, vintage sound, no less clear and precise. Added to this are 3 potentiometers for tone and volume control, allowing you to adapt the sound reproduction to your individual tastes. As an attractive touch, green or red LEDs illuminate the tubes and the perimeter of the unit. On the connectivity side, you'll find a phono input, as well as an RCA input and a 3.5mm headphone output in addition to the RCA output. The aesthetic uniqueness and versatility of this little phono preamplifier will delight many a music lover.
Putting AMPAPA A1 into practice
Ampapa A1 phono preamplifier overview
Overview of the Ampapa A1 phono amplifier
1Power ON-OFF
2Input selector
3LED selector (green / orange)
43.5mm jack headphones output
5Volume control
6Treble control
7Bass control
8RCA phono input
9RCA input
10RCA output
1112V DC power supply via DC jack
Product typePhono preamplifier
Headphones amplifier
TubesJAN5654
Headphones amplifier2x NE5532
Inputs1x RCA Phono (MM)
1x Steroe RCA
Outputs1x Stereo RCA
1x 3.5mm jack headphones output
Input level0.005Vrms (Phono)
0.775Vrms (RCA)
Frequency response20Hz-20KHz (±0.5dB) (RCA) / Ref to RIAA +/-2dB (Phono)
Headphones output power125mW (32Ω)
62.5mW (64Ω)
30mW (128Ω)
Recommended headphones impedance16-300Ω
THD≤ 0.1%
Output level1.5V RMS (RCA)
0.6V RMS (Phono)
SNR≥ 106dB (RCA)
≥ 80dB(Phono)
Compatible replacement tubes6J1, 6K4, 6J5, GE5654W, 6*1N, 6*2N, 6J5, 6A2, etc.
Power supplyDC 12V (≥1.5A) via jack DC
Weight384g
Dimensions153 x 92 x 25mm
Package1x Ampapa A1
2x Tubes 5654
1x RCA interconnect cable
1x Mains adapter
InputPhono
OutputJack 3.5mm
ClassTube amp
The Ampapa A1 is a phono preamplifier specially designed for compatibility with MM cells, based on the use of two JAN5654 tubes for a warm, vintage...
