AUDIOPHONICS T2 Preamplifier Vinyl player (MM) NJM2068 Black
This AUDIOPHONICS T2 preamplifier is designed exclusively for use as an output from a source with a mobile magnet phono cell (vinyl player).
Reference : 17594
44,90 €tax incl.
37,42 € tax excl.
AUDIOPHONICS T2
VINYL PLAYER PREAMPLIFIER 308mVrms / NJM2068 / -75dB SNR THD 0.008%
This controller is exclusively designed for use at the output of a source equiped with a magnetic cell (vinyl player).
Its function is to amplify the signal from your turntable before volume control and amplification.
 Ideally, it will be connected to an integrated amplifier bringing volume control and power amplification altogether. Alternatively, it may be incorporated into a configuration where the preamplifier-volume controller precedes a power amplifier.
Preamplifier NJM2068
This phono preamplifier operates through a high performance,low noise two-way preamplifier NJM2068.
This component is designed for applications requiring high sensitivity processing signals in an environment requiring very low noise.
The NJM2068 has excellent specifications for a phono preamplifier application with distortion barely correlated to the device temperature variations, a wide bandwidth (27MHz), a THD of 0.001% and a slew rate of 6V / microseconds.
Working in concert with a series of well-placed capacitors in a very clean design, AOP NNJM 2068 meets all the conditions to offer a clear, accurate sound with any vinyl player.
Easy Installation & ground connector
Installation is made simple with easy access and well arranged rear panel.
Simply connect the input of the device to your vinyl player with a stereo RCA connector and connect the output to an integrated / pre-amp amplifier via the same connector type.
ChipNJM2068
RMS level308mVrms
SNR-75dB
THD0.01%
InputStereo RCA (phono MM)
Power-SupplyDC 12V 2A (AC adapter not included) - Jack DC 5.5 / 2.5mm
Dimensions130 x 100 x 35 mm
Weight0.25kg
Parts supplied
AUDIOPHONICS T2x1
InputPhono
ClassN/A
Excellent rapport qualité prix
Petit boîtier solide,bien construit,avec façade en alu.
Fait le job.
Parfait
Merci Audiophonics de nous proposer ce type de produit de bonne qualité avec un tarif avantageux.
This review has been posted for AUDIOPHONICS T2 Preamplifier Vinyl player (MM) NJM2068 Black
