FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black
With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube amplification. The FOSI Audio BOX X2 is the ideal companion for a power amplifier or a pair of active speakers.
Reference : 18080
69,00 €tax incl.
57,50 € tax excl.
Shipping date: 05-05-2026.
FOSI AUDIO BOX X2
FOSI AUDIO BOX X2 Préamplificateur Phono MM à Tubes 6A2 Stéréo Noir
The BOX X2 features a 4-level gain control (OFF/39/42/45 dB) on the front panel, as well as a 3.5mm jack auxiliary input for connecting various audio sources such as a telephone, DAC, or others. The rear panel features a stereo RCA input and output with a ground terminal for phono coupling with a turntable (MM).
The FOSI Audio BOX X2 is the ideal companion for a power amplifier or a pair of active speakers. It will boost the sound quality of your hi-fi system. Supplied with a pair of 6A2 (7-pin) tubes, these are easily replaceable by JAN 5654W / 6K4 / 6J1 / 6J4 / GE5654 / 6AK5 / 66*In tubes, if you want a different sound. Overall, the BOX X2 is an excellent entry-level preamplifier.
Product typeMM phono preamplifier with tubes
Tubes2x 6A2
Inputs1x Stereo RCA input (with GND terminal)
1x Auxiliary input 3.5mm jack
Outputs1x RCA stereo
Output voltage level 600Mv @3mV 1kHz
SNR≥ 98dB
THD≤ 0.1%
Frequency responseRIAA standard
Gain adjustmentOff
39dB
42dB
45dB
Compatible cell typeMM
GND terminal
Power supplyDC 12V 1.5A
Dimensions118.5 x 98 x 33mm
Weight315g
Package1x MM tube phono preamplifier Fosi Audio BOX X2
2x 7-pin 6A2 tubes
1x Power supply adapter
1x Stereo RCA to 3.5mm jack cable
InputJack 3.5mm
ClassTube amp
6 reviews
Petit mais costaud
Installé à la place d'un My Groove , réglé sur 39db , la dynamique par rapport à mon ancien appareil est indéniable et appréciable .Ensuite tout dépend de la qualité d'enregistrement des vinyles , mais pour le prix on peu l'acheter les yeux fermés .
Associés avec une platine P1 Rega cellule Bias 2 et ampli Prisma .
This review has been posted for FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black
nickel livraison emballage et le produit
encore en rodage sur une platine ancienne de type dual avec nouvelle cellule type ortofon , je peaufine les réglages et des 39 db cela s'entend déjà pour le prix c'est nickel et je profite du son tube en le couplant à mon ampli
je recommande vivement et ensuite je changerai peut être les tubes pour des plus qualitatifs
Parfait
Rapport qualité prix excellent. Parfait dès 39 db.
Bien faire la liaison avec une entrée auxiliaire ou tuner, mais pas l'entrée phono de l'ampli. Platine Projet, ampli Marantz.
Une merveille
Parfait à tous points de vue. Recul de bruit, distortion, dynamique tout est au top. Rapport qualité prix hallucinant. J'ai revendu mon préampli phono de grande marque à 200 € qui était loin derrière. Aucune hésitation pour ce produit. N'écoutez pas les forums qui disent que les tubes ne servent à rien : si , ils régulent la tension, même s'ils ne sont pas sur le signal. A quand un modèle mc ?
Bon préamplificateur phono
C'est par curiosité que j'ai essayé ce petit préamplificateur .
Le résultat est vraiment étonnant compte tenu se son tarif plus que raisonnable.
Sans le modifier pour le moment, le son est déjà excellent, je le teste avec une Thorens TD 125 MK2 équipée d'une cellule Stanton 681 EEE avec un diamant Jico et la comparaison avec des préamplificateur 10 à 15 fois plus cher est étonnante : pas de souffle, une correction riaa stable et une dynamique superbe.
Cerise sur le gâteau il m'a été fourni avec des tubes Ge 5654w de très bonne qualité.
Je recommande fortement ce produit d'un rapport qualité prix imbattable (réservé bien sur aux cellules MM, on ne peut pas tout avoir).
Jacques
With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the...
