LDOVR TPS7A3301-79XXG Ultra Low Noise Linear Voltage Regulator -3V / -18.5V 1A
The high quality LDOVR TPS7A3301-79XXG regulator provides very low noise (16µVrms) and low-dropout. This model is compatible with both LM79xx and LM337 regulators and is therefore an ideal replacement solution.
Reference : 16288
34,90 €tax incl.
29,08 € tax excl.
LDOVR TPS7A3301 Régulateur de tension linéaire ultra faible bruit -3V / -18.5V 1A
Product type Linear voltage regulator
Output voltage-3V à -18.5V
Output current1A
Input ovltage-3.5V à -25V
Dropout voltage307mV @ 1A
Output voltage noise16µVrms (10Hz, 100kHz)
Ripple rejection72dB (10kHz)
55dB (10Hz, 10MHz)
ProtectionsFixed current limit
Thermal protection
Operating voltage temperature-40°C / +125°C
PCB Dimensions25.4 x 15mm
Output voltage (V)-18.5
Output voltage (V)-3.0
Output current (A)1.0
Input voltage (V)-3.5
Input voltage (V)-25.0
The high quality LDOVR TPS7A3301-79XXG regulator provides very low noise (16µVrms) and low-dropout. This model is compatible with both...
