A real vintage treasure, this Jantzen Wax Coil is made from 99.9998% pure copper 8AWG ribbons hardened with a polymolecular paraffin wax. This technique has been developed by Jantzen Audio in such a way that it does not contain any air pockets in order to have a very advantageous tolerance. The result is a rock-solid, vibration-free coil. Each coil is individually tested with the Clio system.
Product type | Waxed taped coil |
Material | Copper ETP Standard C11000 / IACS Certified |
Section | 8.366mm² (8AWG) |
Inductance | 0.12mH ±2% |
RDC | 0.02Ω ±5% |
Height | 55mm |
Diameter | Ø67mm |
Weight | 1kg |
