WiFi 2.4G DLNA AirPlay Bluetooth 4.0 Receiver 16bit 44.1kHz
This small, compact and practical WiFi and Bluetooth receiver will allow you to transform a classic audio system into a real network player. It will allow you to easily stream your music from devices connected to your local network, while enjoying remote control thanks to the free ALink mobile application.
Reference : 16745
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 16-07-2025.
WiFi / Bluetooth Receiver
WiFi 2.4G DLNA AirPlay Bluetooth 4.0 16bit 44.1kHz
Récepteur WiFi 2.4G DLNA AirPlay Bluetooth 4.0 16bit 44.1kHz
This small, compact and practical WiFi and Bluetooth receiver will allow you to transform a classic audio system into a real network player. It will allow you to easily stream your music from devices connected to your local network, while enjoying remote control thanks to the free ALink mobile application. The latter also offers access to streaming services such as TIDAL or Spotify, as well as to numerous web radio stations via TuneIn and iHeartRadio. It will also allow you, in association with several WiFi receivers, to create a real multi-room ecosystem to equip all your rooms. The Bluetooth reception will allow you to broadcast your music as easily as possible, directly from a smartphone or tablet. On the connectivity side, you'll find RJ45 and 3.5mm jack as inputs and Toslink optical and 3.5mm jack as outputs.
Product typeWiFi / Bluetooth receiver
InputsWiFi
Bluetooth 4.0
1x Ethernet RJ45 10/100M
1x Jack 3.5mm
OutputsWiFi
1x Optical Toslink
1x Jack 3.5mm
WiFi frequency band2.4G
WiFi Protocol802.11 a/b/g/n
Supported Bluetooth protocolsA2DP, AVRCP, PBAP
Supported sampling ratesPCM up to 44.1kHz
SNRAnalog output : > 80dB
Optical output : > 100dB
THDAnalog output : < 1%
Optical output : < 0.01%
Frequency response20Hz - 20kHz
Supply voltage5VDC >500mA
Dimensions140 x 86.5 x 25mm
Weight165g
Package1x WiFi/Bluetooth receiver
1x USB-A to Micro USB power cable
1x RCA to Jack 3.5mm cable
1x Jack 3.5mm cable
InputWiFi
InputJack 3.5mm
InputRJ45
OutputOptical Toslink
OutputWiFi
OutputJack 3.5mm
DAC / ADC ChipNC
Transmission / Reception protocolWiFi
Transmission / Reception protocolDLNA
Supported Bluetooth codecsN/A
This small, compact and practical WiFi and Bluetooth receiver will allow you to transform a classic audio system into a real network player. It...
