XH to XH Wire / 15cm / red
This cable has XHP connector on both end.
The special feature of this model is to have a PTFE coating, an interresting material thanks to its excellent resistance to temperature, corrosion, acid, grease, oxidation, solvent, while ... providing highly reliable electrical insulation. In other words, this XH cable will be quite suitable for any application requiring a reliable wiring time and able to withstand high contraites.
15cm length makes it ideal for complex devices wiring or with a such a display of connectors that some margin is needed to work confortably.
This interconnection cable is ideal for internal wiring of your DIY projects to quickly and easily make connections to XHP sheets.
Its connectors is gold plated for excellent conductivity.
| Specifications | |
| Type of connector | Gold plated XH male connector Gold plated XH male connector |
| Conductor cross section | 21 AWG (0.4mm²) |
| Cable Length | 15cm |
| Cable diameter | 1.2mm |
| Amount | x10 cables |
