![[GRADE S] IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-digital-audio-player-dap-dac-es9038po-balanced-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-black.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Discreet Headphone Amplifier 5W Bluetooth 32bit 768kHz DSD512 MQA Back](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-discreet-headphone-amplifier-5w-bluetooth-32bit-768khz-dsd512-mqa-back.jpg)
Male XLR plug.
Completely removable with soft capsule for excellent support & impact resistance.
The insert of the cable is made of an elastic material for good mechanical stability and compatibility with the types of cables and various ducts.
| Specifications | |
| Type | XLR |
| Genre | Male |
| Number of cores | 3 |
| Mounting | soldering |
| Force insertion | > 20N |
| Insulation resistance | 1000MΩ |
| Rated current | 16A |
| Nominal voltage | 50V |
| Tension max | 1.5KV |
| Connector resistance | <5mO |
| Max cable diameter | 8mm⌀ |
| Color | Black |
| General diameter | 19mm⌀ |
| Length | 72.55 |
| Weight | 32g |
| Insulation material | PU |
| Max cable diameter (mm) | 8.0 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 3 |
| Connector | XLR |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Nickel |
