The mechanical design is weak: to block the cable there is a simple screw that punches the cable and risks to break the internal wiring. Go Neutrik or Furutech, it is wasted money to use this.
Silver Plated Tellurium Copper Male 3 Poles XLR Connector Ø8.5mm (Pair)
Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the contacts. This combination ensures both an excellent signal transmission and a very good contact durability. Mounting is extremely simple, the conductors of your cable can be screwed directly to the XLR connector contacts. The connector accepts cables up to 8.5mm.
Product type | Male XLR connectors |
Poles number | 3 |
Conductor material | Tellurium Copper |
Contacts plating | Silver |
Max cable diameter | Ø8.5mm |
Connection type | To screw |
Quantity | Sold per pair (1 connector with red ring, 1 connector with white ring) |
Insulation material | PU |
Max cable diameter (mm) | 8.5 |
Mounting type | To screw |
Connectic | Male |
Contacts number | 3 |
Connector | XLR |
Contacts Material (Connector) | Tellurium Copper |
Contacts Plating (Connector) | Silver |
Average votes 0.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Roberto G.
