FURUTECH NCF CLEAR LINE XLR Male Audio Signal Optimizer
This XLR connector from Furutech's NFC Clear Line range is designed to optimize the audio signal. It works in "Plug and Play" mode for an instant improvement in sound reproduction with, among other things, a considerable improvement in the signal-to-noise ratio (SNR), better dynamics and more transparent, natural sound coloration.
By buying this product you get 43 loyalty points
Reference : 18386
435,00 €tax incl.
362,50 € tax excl.
Shipping date: 20-08-2025.
FURUTECH NFC CLEAR LINE XLR
FURUTECH CLEAR LINE XLR Male Audio Signal Optimizer
This XLR connector from Furutech's NFC Clear Line range is designed to optimize the audio signal. It works in "Plug and Play" mode for an instant improvement in sound reproduction with, among other things, a considerable improvement in the signal-to-noise ratio (SNR), better dynamics and more transparent, natural sound coloration. This NFC clear Line XLR is designed for use on the XLR inputs of your Hi-Fi equipment, such as amplifiers or DACs. This signal optimization is made possible by NFC (Nano Crystal² formula) technology and the use of hybrid ceramic capacitors.
NFC technology by Furutech (Nano Crystal² formula)
The Clear Line uses Furutech's NCF hybrid structure. This specially developed material incorporating a crystalline material was chosen for its ability to passively eliminate static charges and efficiently dissipate thermal energy. This remarkable material is coupled with ceramic and carbon nano-particles to provide additional piezoelectric damping and resonance absorption. This makes Nano Crystal² Formula an incomparable solution for mechanical and electrical damping.
Hybrid ceramic capacitors
An audio-grade ceramic capacitor also enhances the acoustic performance of your equipment. This passive-type capacitor is coated with a special high-performance damping treatment that eliminates unwanted vibrations and improves sound clarity. Interference induced by the input terminals of your devices is also eliminated for the best possible sound experience.
α Alpha treatment
All metal and conductive parts of the NFC Clear Line XLR have benefited from the Alpha treatment developed by the brand. This consists of a first cryogenization stage, followed by a second demagnetization stage, to increase the material's conductivity. As the contacts are already made of rhodium-plated pure copper, the NFC Clear Line XLR audio signal optimizers benefit from top-of-the-range material treated by advanced technologies.
The screws of this product are fixed. Please do not disassemble or modify by yourself.
Product typeAudio signal optimizer
ConnectorXLR Male
TechnologyNFC
Contacts treatmentα (Alpha)
Body materialStainless steel, nylon and carbon fiber
Contact materialPure copper
Contact platingRhodium
Package1x NFC Clear Line XLR signal optimizer (male)
Insulation materialNylon
Insulation materialCarbon
Insulation materialCrystal Resin
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticMale
Contacts number3
ConnectorXLR
This XLR connector from Furutech's NFC Clear Line range is designed to optimize the audio signal. It works...
