dominique w.
Qualité apparente des connecteurs. Câble trés souple. Permet avant tout de profiter des bénéfices d'une liaison symétrique...
Pedro P.
Merveilleux amplis
C'est mon second achat de cet ampli, c'est dire si j'en suis ravi. Ils remplacent mes anciens modèles...
Andrii V.
IAN CANADA FIFOPI Q7 III
I purchased the Ian Canada FifoPi Q7 III for my custom DAC project, and I am extremely pleased with the results.
The...
Avis clients - Il y a 21103 avis.
Exceptionnel !
Montées sur un pur argent coaxial en 0,8 mm, c'est extraordinaire, une merveille. Meilleures que les autres elecaudio, xangsane et même les klei... En analogique elles ne m'avaient pas impressionné outre mesure, après j'ai pas tout essayé avec mais la.... Grosse claque pour ces petites fiches qui paient pas de mine. Et pour moi aucun problème serrage, ca tient.
Arnoud H.
PANGEA PREMIER XL Câble Phono RCA - RCA + Fil de Masse 1.25m Pangea Audio dévoile avec son câble phono RCA-RCA Premier XL un câble haut de gamme à conducteurs en cuivre pur Cardas Grade One. De plus, ce...
Well balanced phono cable
There is not a lot of information to find on internet for this cable. That triggered my curiosity.
On the manufacturers website I found that the cable are made with Cardas Grade One Copper conductors. Which I think is desirable.
The cable needs time to settle in the system. When settled, the cable gives a very good balance between timbre, spaciousness and clarity. It is difficult to describe. At first it does not appear that special of a cable. It does not have an overly holographic soundstage. It is not overly punchy but something much more natural. Like instruments are played in your room instead of an overly sharp projection where the instruments are outlined to accentuate their presence.
I do not think this cable is for everyone due to their size and stiffness. On an other turntable I have the VDH D-502 cable which is much easier to handle in tight spaces than this cable.
If you play a lot of music with acoustic instruments I think you will be pleasantly surprised with this cable. This cable will not add a aggresiveness to the music, which is sometimes needed for rock, punk, pop or electronic music.
bon cable
le câble onyx 2025 mkII, est très bien en rapport qualité prix ,il fait bien son job.je l'utilise pour un câble phono pour un ami, le câble de masse existant déjà. comme tous ces câble, il faut être soigneux pas le dénuder , il est facile a souder.
rca amphenol
malgré son nom de médicament ,j'utilise régulièrement ces connecteurs RCA pour le design ,leur conception de qualité, et leur prix correcte. la partie en bout en matériau souple ,peut être ajusté selon le diamètre du câble.
Jordan R.
Bien construit & robuste
Acheté pour mettre dans ma baie réseau, mise sur un départ en direct au tableau électrique.
De façon générale le bruit de fond a reculé significativement.
Elle me satisfait pour mon utilisation.
Claudio Marco C.
AP310, incredibile!
L’Audiophonics AP310 si conferma un pre pulito, neutro e silenzioso, capace di gestire il segnale senza aggiungere nulla e senza perdere controllo. Proprio per valorizzare questa impostazione ho scelto, pur non avendone un reale bisogno, di ordinare anche il finale AP300 S250ncx. Per fare un setup di riserva. Non è ancora arrivato, quindi non posso valutarne l’accoppiata, ma l’obiettivo è semplice: completare la catena con un finale coerente e all’altezza della trasparenza dell’AP310. Questo pre l'ho inserito in una catena hiend al posto di un blasonato pre da 2mila euro "moderno" e devo dire che sono davvero stupito!
Stra consigliato, da inserire in catene dove si vuole che la firma sonora arrivi dalla sorgente ed eventualmente ravvivare vecchi finali fin troppo "musicali".
Rolandas L.
FOSI AUDIO ZH3 DAC Préamplificateur Amplificateur Casque Symétrique AK4493SEQ 32bit 768kHz DSD512 Le ZH3 de Fosi Audio est un préamplificateur et amplificateur casque incluant également une fonction DAC. Cet appareil versatile repose sur 4 puces OPA1612 afin...
Fosi ZH3 puikus
Excellent produit, son incroyable ! Je l'utilise avec un casque DT 770 PRO et j'en suis ravi. Sinon, je l'utilise sur PC ou avec un Arylik S10+ et un Icepower 1200 via XLR vers un Dynavoice DM6. C'est un son exceptionnel pour les performances scéniques et en live. Je le recommande vivement.
Eric P.
Après avoir testé plusieurs câbles sur des enceintes Dynaudio j'ai découvert cette marque lors d'échanges avec des audiophiles avec des configurations variées.. Le passage sur des Prima OCC a transformé mon ensemble par rapport à d'autres câbles bien plus onéreux et conseillé par le revendeur Dynaudio notamment des câbles allemands...ces câbles Nova sont destinés à un système secondaire je ne suis étonné par leur qualité intrinsèque du même acabit avec un système de verrouillage...J'espère que Audiophonics continuera à distribuer cette marque
tony r.
NEOTECH NEET-1008 Câble Ethernet RJ45 CAT6E Argent UP-OCC 1m Neotech propose avec son NEET-1008 un excellent câble Ethernet RJ45, profitant d'une conception d'exception. Celui-ci intègre en effet quatre paires de conducteurs...
Excellent câble réseau
Mon expérience avec des câbles réseaux se limite à un Viablue + telegardner monté par mes soins, un Audioquest Vodka et un missing bond ultimate. J'ai pu tester le Neotech neet 3008 avant d'acheter celui ci. Le 3008 est excellent, vivant et avec une bande passante complète (ce qui n'était pas le cas du Missing ou des autres câbles réseaux que j'ai possédé). Le 1008 au branchement était extrêmement doux alors que l'on pourrait s'attendre à l'inverse. Après quelques heures, la vivacité est bien là, comme son petit frère mais il conserve plus de facilité, si bien qu'à fort volume, il n'y a plus aucune agressivité. C'est d'ailleurs la principale différence entre le 3008 et le 1008 sur mon système (Esoteric N05XD + Accuphase A48S) et une légère extension dans l'aigu.
Rolandas L.
Fosi ZH3 puikus
Puikus produktas, skamba nuostabiai, naudoju su ausinemis DT 770 PRO, negaliu atsidžiaugti. Kitu variantu klausau PC ar Arylik S10+ su Icepower 1200 per XLR į Dynavoice DM6, nuostabi scena ir gyvi atlikėjai, rekomenduoju.
Paulo N.
OPAMP roll-of on My OPAMP #2 on FOSI MONO AMP V3
More spatial and even faster transients than the LME I used.
Manuel S.
MUSICIAN MONOCEROS Préamplificateur Symétrique Class A Noir Le Musician Monoceros est un magnifique préamplificateur symétrique high-end, profitant d'une architecture Class A extrêmement performante et d'un...
Fantastic!
I ordered this preAmp in for replacing my old pass clone. The warmth, but also velocity and transients are great. Furthermore there is NO noisefloor. It is black and quiet and so it shows perfect dynamics. The build quality is also great with a cnc metal housing. Great product and great service from audiophonics, as always!
Dominique B.
CLOUDYX CL-BOX PRO Lecteur Réseau Audio WiFi DLNA AirPlay Bluetooth 5.2 Multiroom DAC ES9018K2M Transformez votre installation audio en un véritable système sans fil haute fidélité grâce au CloudyX CL-BOX Pro. Ce streamer audio compact...
CLBox Pro Cloudyx
Remarquable à ce prix. Fait tout ce qu'il annonce et le fait bien. Seul bémol, l'application android a des problèmes de compatibilité avec certains matériel. Ne fonctionne pas sur TAB A Samsung par exemple, se referme systém
Dominique B.
CLBox Pro Cloudyx
Remarquable à ce prix ! Fait ce qu'il annonce et bioen. L'a
Aleksy R.
AUDIOPHONICS MPA-S250NCX RCA Amplificateur de Puissance Class D Stéréo NcoreX NCx252MP 2x250W 4 Ohm Le Audiophonics MPA-S250NCX RCA est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NCx252MP. Cette solution est idéale pour...
Best choice for this money
This amplifier is simply a sensation compared to my Marantz PM5003! Paired with the WIIM Ultra and KEF C7X, it delivers a truly mind-blowing musical experience. The entire soundstage has opened up, everything is clearly separated, the bass is tight and punchy, and the clarity is incredible. I’m listening to lossless and FLAC formats from a USB drive. Highly recommended — great job, guys!
Jean-Marie M.
Pertinant
Il est pénible, sur le terrain, de devoir passer deux câbles symétriques alors qu’un seul suffit.
Ce câble correspond exactement à ce que je cherchais. Il faut en revanche confectionner soi-même les extrémités pour y installer les connecteurs souhaités.
Point délicat : la gaine extérieure est robuste, mais les petits câbles symétriques internes sont très fragiles. Il faut donc les renforcer avec de la gaine thermo épaisse et trouver une astuce propre au point de séparation.
Après un peu de travail méticuleux pour obtenir une solution robuste, le résultat final est TOP.
Dommage de ne pas pouvoir poster une photo
Jean François M.
LUDIC AESIR Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 1m Le Ludic Aesir est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Cable secteur Ludic
Câble secteur de grande qualité (câble haute teneur en cuivre, grosse section du cuivre et fiches Schuko de très bonne qualité). Attention à la rigidité du câble en cuivre. En tenir compte lors de la mise en place.
Jean François M.
LUDIC KRATOS Distributeur Secteur Filtré 6 Prises Filtrées + 2 Prises Directes Schuko Noir Le Ludic Kratos est un distributeur secteur avec section filtrée extrêmement performant, capable de soutenir la comparaison avec les produits les plus haut de...
Ludic Kratos
produit de très bonne qualité. Dommage que les 6 prises filtrées ne soient en placage or ou argent pour une meilleure conductibilité. Ecran en façade très utile. Très bon produit.
Jean François M.
VIBORG VE501G Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent / Or 24K Ø19mm Ce connecteur Schuko Viborg VE501G est idéal pour la conception et l'amélioration de câbles secteur hautes performances et de grande qualité. Ses...
fiche schuko viborg
Excellente fiche de très bonne qualité et très bien conçue.
Didier T.
OPA2210 AOP Double DIP8 (Unité) Cet AOP OPA2210 est un AOP double monté sur DIP8. Il est construit sur le procédé de semi-conducteur bipolaire...
Un réel délice
Très liquide et suave, il procure une grande ampleur et des timbres d'une rare élégance.
Sa profondeur harmonique est réelle.
Très transparent, il est néanmoins aux antipodes d'une esthétique qui veut faire absolument "du détail pour épater la galerie".
Le 2210 livre la musique sans aucun stress et avec une grande délicatesse : tout coule avec une remarquable aisance.
Il fait merveille dans un préampli phono MM Graham Slee Communicator Amp 2.
A réserver au mélomanes avertis qui utilisent leur matériel pour déguster la musique et non l'inverse.
Ps : lui laisser le temps d'être sous tension et de "travailler" quelques dizaines d'heures avant tout avis pertinent.
Didier T.
Très bien mais pas spectaculaire
Très "3D" et immersif, il est aussi très informatif avec beaucoup d'air qui circule.
Très droit et neutre, son rendu est de nature assez tendue.
Il restitue à l façon d'un 2134 amélioré.
Dans certains cas, il peut possiblement engendrer un manque d'émotion.
A mon sens, plus destiné aux audiophiles qu'aux mélomanes.
Claudio c.
EARACOUSTICS SPA PRO Écouteurs Intra-Auriculaires IEM Dynamique 16 Ohm 113dB 5Hz-40kHz Les SPA-PRO de EarAcoustic sont des écouteurs intra-auriculaires reposant sur un haut-parleur dynamique à double circuit magnétique N52 et à la...
TOUT CE QUE J AIME DANS UNE BONNE PAIRE D ECOUTEUR
J e suis pas déçu de mon achat , très très bon rapport qualité .
Le son est complet dans tout les registre.
Mario d.
Transformateur Torique 100VA 2x15V 3.3A Ce transformateur torique de haute qualité délivre une puissance de 100VA 2x15V 3.3A et sera un choix idéal notamment pour la réalisation de vos...
13% higher voltage.
I purchased this 100VA toroidal transformer with 2×15V secondary (3.3A) for a linear power supply in an audio project. Mechanically the transformer looks good: neatly wound, compact, and it operates silently without any audible mechanical hum. Installation is straightforward and the wiring is clearly identified.
However, what I noticed is that the output voltage is noticeably higher than specified. Instead of the rated 2×15V AC, I measure approximately 2×17V AC with no load. That is about 13% higher than the nominal voltage.
To be fair, this behavior is not completely unusual for transformers. Many transformers are specified at their nominal load, and when measured without load the voltage can be significantly higher. Still, 17V instead of 15V is quite a large deviation, especially if the transformer is intended for power supplies that rely on accurate secondary voltages.
After rectification and smoothing this results in roughly ±23–24V DC, which can increase heat dissipation in linear voltage regulators and may not be ideal for circuits designed around a typical ±15V supply.
Pros
✔ Solid build quality
✔ Compact size
✔ No mechanical hum or vibration
✔ Sufficient power capacity (100VA)
Cons
✖ Output voltage significantly higher than specified (≈17V instead of 15V)
✖ Can cause extra heat in linear regulator circuits
⭐ Conclusion
Overall the transformer appears well built and works fine electrically, but the higher-than-expected no-load voltage should be taken into account when designing a power supply. If your design requires tighter voltage margins, you might want to consider a 2×12V or 2×14V transformer instead.
Joseph C.
EARACOUSTIC STA-HI END Écouteurs Intra-Auriculaires IEM Dynamique 32 Ohm 110dB 10Hz-30kHz Les STA-HI END de EarAcoustic sont des écouteurs intra-auriculaires se reposant sur deux haut-parleurs dynamiques afin de proposer d’excellentes performances pour...
Mon meilleur iem budget
J’ai eut ma période de tests d’iem budget à moins de 50€, des renommées tels que Conch, zéro, tangzu, chu ii avec lesquels la question est plutôt le quel sonne le moins pire de tous…
J’ai également l’Artti R1 , qui est pas mauvais mais avec lequel on s’endort car aucune vie…
Quand à celui ci, il est parfaitement équilibré entre rondeur et vie pétillante :), tout sonne très propre sans rien mis en avant, excellente définition, ouverture et largeur stéréo. Il est un peu long à roder car les premières heures il manque de basses et de punch le rendant un poil agressif. Mais oui, il s’agit du meilleur iem que j’ai possédé à ces tarifs là :)
Miles B.
Good value and quality
These are a solid alternative to the more expensive offerings from furutech. I can not speak in terms of metals used but the general construction and good connection grip make them a good buy. They also tamed some hum on my active speakers which was an unexpected benefit, I recommend them if available space behind unit is not an issue.
Frédéric B.
Bons résultats
Branché sur un ampli Rotel RB 1070, une amélioration des plans et de l'ouverture se fait entendre dés la première écoute. Le cable n'apporte pas de coloration particulière et peu donc être jugé neutre, ce qui est appréciable.Les graves sont tendus et les aigus filent avec douceurs et clartés ... La fabrication du câble respire la qualité, par contre son diamètre et son poids implique un dégagement important à l'arrière de l'appareil . Satisfait de cet achat et du rapport qualité prix.
Emmanuel A.
CANARE L-5CFB Câble coaxial 75 Ohm blindé Haute performance Ø7.7mm Câble conçu et fabriqué au Japon par la célèbre firme CANARE, ce câble coaxial 75 Ohm L-5CFB de très haute qualité était originellement dédié au marché professionnel du broadcast.
Top pour caisson de basse
Je l’ai acheter pour remplacer un câble atlas pour une liaison lfe entre mon subwoofer svs4000 et mon ampli hc denon
Et bien le résulta est parfait
Les impact sont percutant à souhait les basses ne bave pas
Il est top et pour un prix raisonnable il remplacera largement des modèle de 10fois ce prix voir plus
Mugdim K.
TOPPING PROFESSIONAL E1X2 OTG Interface Audio USB 1 Entrée 2 Sorties 24bit 192kHz Blanc Topping propose avec la E1x2 une excellente interface audio, pensée pour les musiciens et professionnels de l'audio. Cette très bonne interface offre un...
Good sound for little money.
Very good sound card, I use it for various purposes. The inputs are quiet, the outputs are strong enough. The headphone output is a special story, I have a Hifiman he400se and I am very satisfied with the output amplification. Clear sound without delay. The software for Windows is simple but with measured information and options.
Mugdim K.
But
The headphones are good, if you don't use EQ, they are listenable, but they have too many highs and lack bass.
Since there are planar drivers inside, you can slightly raise the lows / lower the highs, with EQ, so they sound much better. All in all, for headphones under 100 euros, they are too good.
Frédéric B.
Belle amélioration !
Branché sur un ampli Rotel RB1070, on peut ressentir une belle amélioration de l'image sonore. La scène s'élargit en largeur et profondeur, les instruments et interprètes respirent mieux contribuant à une belle écoute ! Un très bon cable que je recommande.
Ron L.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz Ce reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce à une horloge locale de haute...
Erg goed
Mijn coax uitgang van de Oppo UDP 203 Vanity welke DoP 64 uitstuurt is aanzienlijk verbeterd in helderheid diepte stilte en dynamiek.
Echt een aanrader.
Gevoed met een IFi 5v voeding
Rumen S.
Borniers Isolés Plaqué Or Ø16x43mm (La paire) Ces borniers abordables profitent d'une fabrication de qualité et d'un design aussi simple qu'efficace. Avec des contacts plaqués or, ils assurent une bonne...
Nice!
For this price, there’s nothing more to wish for.
Except… maybe one more nut for easier installation. But even much more expensive connectors suffer from this drawback.
Rumen S.
Raccord pour Axe de Potentiomètre flexible Ce raccord pour axe de potentiomètre accepte des axes d'un diamètre de 6mm maximum. Le montage se fait simplement à l'aide de vis hexagonales de 1.5mm.
Very good!
Exceptionally useful part! However, be careful when tightening the bolts. The material is still plastic, and the thread can be damaged.
Andis S.
Module Ladder DAC R2R NOS Symétrique 24bit 384kHz Ce module Ladder DAC offre une conception de très haute qualité, avec un étage de conversion R2R, utilisant un CPLD Altera MAX II par canal, associés...
Easy to build DAC
Easy to build great sounding converter. Going to swap opamps.
Vivien S.
Filtre Jack DC 5V à Supercondensateurs vers Jack DC Ce filtre jack DC 5V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 4...
Pratique sur Raspberry Pi
pour le son je ne suis pas sûr de percevoir une différence derrière mon allo usbridge.
Par contre c'est très pratique pour éteindre correctement son RPI :
1 lancer l'extinction du RPI via un mini clavier type sayo device
2 couper immédiatement l'alimentation du filtre
... le RPI a le temps de terminer sa procédure d'arrêt propre sur la charge des capacités du filtre, puis lorsqu'elle est épuisée l'alimentation est totalement coupée pour le RPI
cela m'évite de rester planté devant mon streamer pendant 1min pour qu'il s'éteigne.
à l'allumage, juste rélancer l'alimentation, le filtre monte en charge (1-2min) puis lance l'alimentation du RPi qui démarre.
bref très pratique
Vivien S.
transfigure mon caisson
mon caisson est parfait depuis que j'utilise cet Y sur les entrées rca plutôt que celle LFE.
La différence est plus qu'audible.
Ivan B.
BURSON AUDIO V7 CLASSIC PRO AOP Simple (La paire) Évolution du V6 Classic, le V7 Classic Pro atteint désormais un niveau de bruit ultra-faible tout en conservant les aigus étincellants qui font la force de...
Significant improvement for Gustard DAC and KEF 105/3
I installed two Burson V7 Classic Single op-amps in my Gustard DAC, which is connected to a Sony TA-F870ES amplifier and KEF 105/3 speakers.
The upgrade is clearly audible. The soundstage opened up significantly, becoming deeper and more precise. What I like about the V7 Classic is the natural, organic tone—the mid-range is rich and the highs are detailed but never fatiguing. Even with my current cables, the transparency has improved. A very solid upgrade for anyone looking to get more musicality out of their system.
Luís A.
Dangereux
Ça a fonctionné pendant un mois, puis ça a commencé à faire du bruit et les appareils (téléviseur et chaîne hi-fi) ont commencé à clignoter.
Jonathan V.
Super qualité
Bon je me suis fais des cables instru pour guitares, particulièrement sensibles aux perturbations. Dans un premier temps j'ai utilisé ma soudure, j'avais un cable identique avec connectiques identiques acheté en magasin, j'ai comparé le son c'était la Cata. Seule la soudure était différente, j'ai commandée celle-ci, certes chère mais après installation c'est top! son parfaitement identique au cable magasin à 60e... parfait merci, bon matos et arrivé hyper vite en prime ;-)
Alain C.
Bon produit, mais attention à ne pas trop forcer sur la patte de masse, pour la détordre par exemple, elle se désolidarise facilement, et il faut être minutieux pour les soudures, sous la loupe, c'est mieux !
Raul P.
TINYSINE TSA7804B Module Amplificateur Class D TPA3116D2 DSP Bluetooth 5.0 4x50W 4 Ohm Le module TinySine TSA7804B est une carte d'amplification Class D à quatre canaux avec DSP et récepteur Bluetooth intégrés. Celle-ci est capable de...
Great for simpel use
Great amp for stereo speaker or sound bar. Only part missing would be to have more gpio´s to control the DSP
Gérard B.
TONEWINNER AT-500 Processeur Audio-Vidéo / Préamplificateur Home Cinéma 8K Dolby Atmos 16 Canaux 9.3.4 / 7.3.6 Le Tonewinner AT-500 est un processeur home-cinéma 8K conçu pour les configurations immersives jusqu’en 9.3.4 ou 7.3.6. Il assure le décodage complet...
Tonewinner AT-500
Correspond bien à mes attentes. Quelles sont les différences entre les modes "Pure" et "Direct"? Mais j'ai constaté un bug: sur certaines entrées, je n'ai pas le son. Je suis obligé de changer le mode (audio) de Direct jusqu'à "Dolby Upload" pour obtenir du son, puis je reviens au mode "Direct" que j'ai choisi. J'ai tenté de me connecter en WiFi pour réaliser une mise à jour (si elle existe), mais je n'ai pas pu rentrer ma clé WEP, le password WiFi ne permet pas de rentrer tous les caractères (et je ne sais pas si les majuscules sont prises en compte.....
laurent C.
mon ressenti: appareil aux finitions fragiles mais excellente sonorité
Trois Fosi v3 mono pour alimenter et soulager mon onkyo cinéma RZ 30 en face avant
(enceinte klipsch 500 rp) sonorité plutôt sympathique et détaillé de l'ensemble, un cran au-dessus de l'ampli l'onkyo. Finition visuelle apparente excellente mais les borniers enceintes sont médiocre et fragile a l'arrière de l'appareil, j'utilise des fiches bananes et les borniers bouge de partout ! combien de temps cela va tenir ? sur un des amplis le voyant de mise en route ne s'allume pas ! tous ça me semble bien fragile. Ampli minuscule mais profusion de câbles pas simple a organiser. tout de méme beaucoup d'inconvénients heureusement la qualité sonore est bien la
Maxime V.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Argent Le nouveau petit DAC de bureau D50 III de la marque Topping possède quelques mises à jour lui permettant d'obtenir de meilleures performances que ses...
RQP au top
Une parfaite qualité de restitution (détails, dynamique, ...) dans un mini format et peu importe l'entrée choisie. Alimenté par une linéaire régulée de chez Audiophonics. J'exploite toutes ses entrées : coaxial, usb et toslink. Sub branché sur la sortie RCA et ampli de puissance sur xlr.
La télécommande en mode IR fonctionne très bien, alors qu'elle met un temps de réveil beaucoup trop long en BT (idem modèles plus haut de gamme de la marque).
Pourquoi payer plus cher.
François N.
GUSTARD U26 Interface Numérique USB I2S SPDIF 32bit 1536kHz DSD2048 Noir Le Gustard U26 est une interface numérique USB de haute précision, conçue pour offrir une qualité audio ultra-haute résolution aux audiophiles...
Gustard U 26.
Le Gustard U26 associé à mon A26. Il a métamorphosé ce dernier tant au niveau des basses, de l’aération. Plus de hauteur et de profondeur. Des petits détails qui étaient enfouis ressortent mieux. Très belle amélioration dans mon système.
jean-Luc R.
DAYTON AUDIO SPA100-D Amplificateur Class D pour Subwoofer 100W 20Hz-200Hz L'amplificateur pour subwoofer à haut rendement Dayton Audio SPA100-D regroupe des fonctions normalement disponibles sur de gros amplificateurs dans un châssis...
bon produit pour un prix accessible
Bon produit, le pilotage automatique est très pratique, puissance largement suffisante pour piloter un hp de 38cm.
j'ai un très léger ronflement malgré le passage par une fibre optique mon cable de fin ne doit pas être assez blindé, ou le ronflement vient de mon berhinger FBQ. Mais à mi puissance c'est très supportable
La prise livrée en standard n'était pas faite pour la France , erreur rectifiée instantanément (au délais de livraison près) par le SAV
il manque quand même un gabarit pour faire la lumière dans le caisson
Henri c.
exelent
je l'ai utilisé pour lisser le haut medium d'un L12P110K RCF qui a un BL
de 23 ! ,ça n’a pas altéré la dynamique qui est très bonne.
le son est devenu plus fouillé ,plus vivant,mieux équilibré.
il faut soigner le câblage aussi, j'ai mis du 4mm2 Cu/Ag.
Frank D.
LHY AUDIO LPS25VA Alimentation Linéaire Régulée Faible Bruit USB 220V vers 5V 2A 25VA Voici une alimentation linéaire régulée et stable pour tout projet DIY audiophile de haute qualité. Tous les raffinements techniques...
Top Produkt & Top Shop
Hervorragendes LPS zum sehr guten Preis, zuverlässig verpackt und schnell geliefert.
Vielen, herzlichen Dank an das ganze AUDIOPHONICS Team, ihr seid die besten
Frédéric B.
LHY AUDIO EFI Isolateur Réseau Galvanique Optique Noir Le EFI de LHY Audio met en œuvre une isolation galvanique complète par conversion optique, transformant le signal Ethernet RJ45 en transmission par fibre optique...
Top produit
Cet avis est bien sûr subjectif.
Amélioration de la clarté, de la dynamique et diminution du bruit.
Matériel sur lequel il est installé : streamer Auralic Aries G2.2, DAC Musician. Pré-ampli Parasound JC2, ampli Audiaflight FLS10 ( utiliser en bloc de puissance), enceintes EgglestonWorks Andra 3 SE.
Frédéric
michel s.
Bon rapport qualité/prix
Bon câble, bonne isolation, connecteurs corrects et bonne fabrication. (Bien que les élastiques rouges et blancs ne tiennent pas très bien)
Ce n’est pas le plus neutre ni le plus musical des câbles que je possède bien sûr mais pour l’emploi que j’en fait il me convient tout à fait.
