Aluminium chassis for DAC I-Sabre V3 / DAC I-TDA1387 et Raspberry Pi 3
This new version of the 100% Aluminum case is designed to accommodate the Raspberry Pi 3 or Pi 2 couple and the Audiophonics I-Sabre ES9023 V3 DAC.
Reference : 10857
29,00 €tax incl.
24,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
It has all the inputs / outputs necessary for its connector, as well as the power supply (Jack DC 5.5 / 2.5mm).
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Thanks to this sleek and discreet case, you have a high-performance audio solution at an excellent value for money.
Characteristics :
  • Housing 100% Aluminum
  • Black anodized
  • Dimensions: 102x169x50mm
  • Weight: 450g
  • Port RJ45 x1
  • USB-A x4 port
  • Stereo analog output (Ø 12mm)
  • Input Jack DC 5.5 / 2.5mm (Ø 9mm)
  • Switch position (Ø 19mm)
  • Screws provided
Bundle DAC I-SABRE V3 + Raspberry Pi 3
Illustration with a Raspberry Pi 3 & DAC Audiophonics I-Sabre V3 (not included)
MaterialMetal
Bonne base pour un streamer audio
Boitier utilisé pour le montage d'un streamer audio à base de RPi (Serveur squeezebox sur base de Max2Play).
Comme son grand frère la finition est excellente et le montage aisé (Pi + DAC + carte ATXraspi)
This review has been posted for Aluminium chassis for DAC I-Sabre V3 / DAC I-TDA1387 et Raspberry Pi 3
This new version of the 100% Aluminum case is designed to accommodate the  Raspberry Pi 3  or Pi 2 couple and the ...
