WONDOM AA-AB32313 GREMLIN Amplifier Board STA516B & TC2001 T-AMP Class D 2 x 400 Watts 3 Ohms 48V
-20%
Reduced price!
Reference : 10876
66,90 €tax incl.
-20%
53,52 €tax incl.
44,60 € tax excl.
Shipping date: 19-11-2026.
Here is the T-AMP amplifier module in Class D delivering 2 x 400 Watts under 3 Ohms, it can power a very wide range of speakers.
Ideal for all types of DIY projects, it can be integrated easily into your audio systems thanks to its simple implementation.
The T-AMP technology used by SURE provides low distortion and low noise levels. The fan turns on when the radiator temperature reaches 45 degrees Celsius, and stops when the temperature drops below 40 degrees.
Due to its power supply range it is very convenient and can easily run on batteries. It also has a DC Jack input.
Characteristics :
  • Amplifier T-AMP
  • Architecture Class D
  • Topology PBTL (Parallel Bridge-Tied Load)
  • Excellent audio quality
  • Active heatsink
  • Line level input (2VRMS) Solder or RCA pads
  • Over Current and Overtemperature Protection
  • Hp protection ("plocs")
  • Output power: 400W @ 3 ohms 48V DC (10% THD + N), 234W @ 3 ohms 48V DC (1% THD + N)
  • Gain (Min / Type / Max): 29/31/32 dB
  • Support 2x 6 pin for Volume Control Kit
  • Input voltage: 15 V
  • Input Impedance: 33 Kohm
  • Frequency response: 22Hz - 22kHz
  • Operating Temperature Range: 0 to 50 ° C
  • Yield:> 90% at 48V
  • nourishmeion: 15 to 48 VDC (48V recommended)
  • Dimensions between centers: 110 x 80 mm
  • Dimensions: 122 x 91.5 x 40 mm
  • Weight: 290g
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipSTA516B
Power (W)400.0
Excellent, tout à fait en ligne avec la réputation du Gremlin
Alimenté par une meanwell 36V 300W, cet ampli est surprenant. Ne vous attendez pas à un gain important (le gain est plutôt dans cette configuration d'alimentation celui d'un 2x40W classique). En revanche il y a énormément de "headroom" et la dynamique est fantastique. Je recommande de casser la tirelire et passer sur la grosse alim 48V, ne lésinez pas. Il faut normalement bypasser les capa d'entrée et remplacer par des capa de bonne qualité, mais même sans ça le résultat est bluffant, même (et surtout) sur des enceintes difficiles comm mes VTLs Jordan.
This review has been posted for WONDOM AA-AB32313 GREMLIN Amplifier Board STA516B & TC2001 T-AMP Class D 2 x 400 Watts 3 Ohms 48V
