WONDOM AA-AB32178 Amplifier Module TPA3116 Class D 2 x 50 Watts 4 Ohms
4.3 / 5
Reference : 10052
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 01-12-2026.
This compact amplifier module TPA3116 in Class D is of a formidable efficiency: it delivers 2x 50W under 4 Ohms.
Ideal for all types of DIY projects, it will easily integrate into your audio systems thanks to its simplified implementation.
Due to its power supply range it is very convenient and can easily run on batteries. It has a DC 5.5 / 2.5mm jack input.
Characteristics :
  • Amplifier TPA3116
  • Architecture Class D
  • Excellent audio quality
  • Line level input (2VRMS) Solder or RCA pads
  • Over Current and Overtemperature Protection
  • Hp protection ("plocs")
  • Power: 25W x 2 @ 4 ohms (<0.1% THD + N), 50W x 2 @ 4 ohms (<10% THD + N)
  • Input Impedance: 22 kohm
  • Frequency response: 20Hz - 22kHz to +/- 3dB
  • Operating Temperature Range: 0 to 50 ° C
  • Yield: 90% to 12V
  • Power supply: 8 to 26VDC (2 to 6A) / DC Jack 5.5 / 2.5mm
  • Dimensions: 91x68mm
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)50.0
3 reviews
LA MEJOR ETAPA DE MI VIDA
Me explico, este modulo por lo que me costo, 26€, que tiene la caracteristica especial de ser "filterless" ya sabeis sin filtro de altas frecuencias, juto con mi preamplificador de linea a transformadores "tvc preamp" y si y solo si esta alimentado por una fuente de alimentacion como minimo si es SMPS marca Meanwell de 12v 4,5A y para "uso medico" (de venta en una conocida pagina de componentes electronicos) suena MEJOR que una etapa de potencia Meridian 556 made in england con altavoces B&W mas extenso mas liquido los medios mas dinamico los graves mas extenso y detallado el agudo pero sin ser estridente.... perfecta!
This review has been posted for WONDOM AA-AB32178 Amplifier Module TPA3116 Class D 2 x 50 Watts 4 Ohms
Bien pour le prix
Fonctionne parfaitement, borniers à vis fragile mais accessible pour être ressoudé. Couverture des fréquences incomplète : chute rapidement en dessous de 80 Hz
Bon ampli 12Vdc
J'apprécie le rapport qualité/prix.
Le petit plus : entrées stand by et mute
En moins : tenir le connecteur bornier à visser si serrage fort, la solidité du bornier est un peu en dessous de l'image globale du produit.
