AUDIO-GD NFB-11 DAC ES9018 / Headphone Preamplifier / Amplifier DSD 32bit / 384kHz
By buying this product you get 38 loyalty points
Reference : 8925
389,00 €tax incl.
324,17 € tax excl.
AUDIO-GD NFB-11 (2015)
DAC / Headphone Preamplifier / Amplifier
Versatile, efficient, and very affordable ...
A true Swiss audiophile knife, this NFB-11 combines the functions of DAC, preamplifier, and headphone amplifier, just that.NFB is the acronym for Non-Feedback, a technology used by Audio-GD so that it does not "color" the sound at the output stage electronics, thus providing a more neutral sound than professional.
A modern USB interface
The integrated ES9018 SABER allows you to manage 32Bit / 192kHz sources in both SPDIF and USB, and up to 384kHz in USB. In order to use the NFB-11 on Windows via its USB-B input on the rear panel, you must first download the USB-32 Driver, available on the Audio-GD website: ef = "http://www.audio-gd.com/Pro/dac/USB32/USB32EN.htm" target = "_ blank">USB-32DSD (DSD64, DSD128, DXD support)
Stunning sound reproduction:
32bit / 384kHz / DSD / DXD / TCXO
The 100% discreet design of this preamplifier (no PDO) is backed by a high power supply capable of providing the necessary energy. The ALPS RK27, the 24K Gold Plated RCs, and the Nover (UK) capacitors have fhas been specially manufactured on Audio-GD specifications. The Toshiba and Hitachi transistors were manually paired.
TCXO - 100MHz
Usually the Audio-GD devices are equipped with the standard 80MHz clock, except this Audio-GD NFB-11 includes the 100MHz TCXO Ultra Low Jitter option, perfectly associated with the ES9018. This TCXO (Temperature Compensated X (Crystal) Oscillator) clock is more precise and significantly reduces the jitter.
SABER ES9018
This DAC / Preamplifier / Headphone Amplifier High Fidelity is equipped with the famous ESS ES9018 32 bit / 384kHz. This conversion chips is capable of reading high definition formats from DSD to PCM. The NFB-11 has a "Mute" switch on the rear panel, stamped with 1 or 2. It is dedicated to playing DSD files. Set it to 1 to enable Mute Design (DSD file playback). Set it to 2 for playing PCM files.
Features:/ Div>
Ratio Signal Noise: 118dB
Level ofexit: Headphones (HP) 10V RMS / Preamplifier (Variable) 5V Max / DAC (Fixed) 2.25V RMS
Output Power (Headphone): 3500mW / 25Ohm - 1800mW / 50Ohm - 900mW / 100Ohm - 300mW / 300Ohm - 150mW / 600Ohm
Output Impedance: 2 Ohm (Headphone Output HP) / 2 Ohm (DAC Output Fixed)
Supported Operating Systems: Windows (44.1kHz to 192kHz) / OSX (44.1kHzto 384kHz) / Linux (44.1kHz to 192kHz)
Sample rate: USB (44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz) Coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHzOptical: 44.1kHz, 48kHz, 88.2kHz, 96kHzDSD 64/128 and DXD
Input Sensitivity: 0.5Vp-p (75 Ohm, Coaxial) / 19dBm (Optical) / USB1.1 and 2.0 (Full Speed)
Frequency response: 20Hz - 20kHz (-0.2dB) / 3Hz - 350kHz (analog circuit)
Power Consumption: 12WDimensions: 180x220x55mWeight: 2kgIncluded Accessories: Power cord / USB cable
7 reviews
Un excellent DAC
Un rapport qualité indéniable, le son est d'un très grande propreté et la lecture DSD est un réel plaisir.
C'est une grosse claque !
Chauffe pas mal, de ma récente expérience sur ce dac, le mettre debout sur la tranche dissipe mieux la chaleur.
Merci à toute l'équipe d'audiophonics qui on été à l'écoute et qui m'ont bien renseigné sur ce produit.
This review has been posted for AUDIO-GD NFB-11 DAC ES9018 / Headphone Preamplifier / Amplifier DSD 32bit / 384kHz
Super rapport qualité/prix
Sidérant cet ampli dac casque.
Les performances sont excellentes et n'ayant aucun rapport avec le prix ridicule affiché compte tenu des qualités de cette petite boite noire.
J'ia donc couplé ce fameux nfb-11 avec mes casques :
Beyerdynamic dt880 600 ohms
Beyerdynamic dt990 600 ohms
AKG K702
Sennheiser HD600
Grado SR125 avec pad L cushion
Et bientot on verra le résultat avec un msr7 et un HD650.(moddé)
Cet ampli dac se marie très très bien avec l'ensemble de mes casques.
Je possède aussi un autre ampli casque Violectric v200 qui est associé avec mon lecteur réseau hifi (pioneer dac sabre) et ampli hifi (nad) donc je peux vous assurer que cet audi-gd ne démérite pas et peut tenir tête à un ensemble même pus cher, même si mon autre ensemble fait mieux.
Cet audio-gd a été une très bonne surprise et compte du prix son rapport qualité/prix est archi impressionnant.
Le grave est tendu, propre et descend bas.
Le medium est top et très précis que ça soit les voix suaves, les cuivres et la caisse claire etc tout sonne juste et diablement bien.
L'aigu file haut sans être abrasif même avec des casques assez claires.
Le soundstage et la spatialsation sont au rendez-vous..
En un mot vous allez tout simplement redécouvrir votre casque hifi.
Un petit bémol tout de même:
J'ai vraiment galérer pour isntaller le driver sur Windows 10.
J'ai du finalement me résoudre à ne pas suivre la documentation d'audio gd qui ne marche pas car le driver ne 'installe pas (une erreur s'affiche).
J'ai été dans gestion des périphériques et j'ai installer manuellement le driver VISTA64 qui se trouve dans le zip du driver V2 d'AUDIO GD.
De plus, n'oubliez pas de désactiver le format 48 khz et mettre 44.1 khz au risque d'avoir un son assez mauvais et congestionné (voir dans les propriétés son de l'audio gd une fois reconnu par WIndows 10)..
je vais aussi inverstir dans un cable otg android afin de connecter le dac à mon smartphon android, avec le programme usb audio player pro j'ai bon espoir qu'il soit reconnu, je croise les doigts).
Je recommande vivement.
Excelent
Bonjour je me suis laissé tenter par un NFB11 pour brancher sur mon Pc ... Je pensai avoir une très bonne carte son ... c'est peut être le cas mais je dois reconnaître que le gain est notable sur mon AKG701 c'est un autre monde .... à découvrir pour les autres produits de la gamme...
Vraiment très bon !!!
Après acquisition d'un casque AKG Q701 à vil prix pour succéder à un Sennheiser Momentum On Ear, il me fallait un successeur à mon petit Fiio E10k malheureusement pas assez balaise pour tirer la quintessence d'un tel casque.
Après avoir écumé les forums et sur conseil d'Audiophonics je me suis donc décidé à acheter l'audio-GD NFB 11.
Aujourd'hui après 3 semaines d'écoute, je peux dire que j'ai fait le bon choix !
Couplé à un casque AKG Q701 c'est vraiment excellent ! La restitution est incroyable , tout est net et aéré, les instruments se détachent parfaitement les un des autres sans pour autant tomber dans ce côté hyper analytique. On redécouvre la musique, on découvre des sons jamais entendu sur des morceaux écoutés milles fois !
Attention toutefois pour ceux qui sont habitué à une sonorité plus boomy , moi qui vient d'un casque ayant tendance à surjouer le grave ( Momentum On Ear ) au début c'est hyper déroutant !
Une fois habitué au nouveau son on rentre dans une autre dimension, tout simplement...
J'ai également changé le cable USB d'origine par un Supra USB c'est clairement meilleur dans la restitution !
Parfait également sur mon petit SMSL SA-50 et mes Eltax, bref je recommande ! Du très bon matériel qui saura m'accompagner quelques années à n'en pas douter :-)
Un DAC/Ampli casque excellent...
Reçu hier, bravo à l'équipe Audiophonics pour la rapidité et la qualité du service, après un branchement sans problème, j'ai commencé l'écoute pendant plusieurs heures. Sans rodage, le DAC a une musicalité remarquable et une précision dans la définition sans faille. J'ai pu testé mes fichiers DSD, DXD et Flac. Pas de doute c'est un Grand DAC. Revers de la médaille, gare aux fichiers pourris type MP3 encodés à la va vite, ce DAC vous le fera savoir, mais avec des enregistrements de qualité même très anciens, c'est le nirvana musical. La fabrication est impeccable, la simplicité de mise en œuvre, les branchements il n'y a rien à redire. J'ai suivi les deux avis précédent pour mon achat et je m'en félicite.
 (3)
