AUNE S16 DAC DSD / DXD AK4495S 32bit / 384kHz XMOS
4.3 / 5
By buying this product you get 66 loyalty points
Reference : 9241
669,00 €tax incl.
557,50 € tax excl.
You will find the new version of the S16 here:AUNE S16 (2016) DAC DSD / DXD
The AUNE S16 is the latest addition to the AUNE brand.
It is equipped with the best in each domain and allows you to have a high quality conversion that supports all sampling rates as well as the DSD.
Equipped with four digital inputs, two analog RCA and XLR outputs from a selection of sources and a volume control by PGA2311, it is a serious converter with significant advantages.
Features:/ Strong>
  • White TFT display
  • DAC: AK4495S
  • Natively recognized on Mac OS and Linux without drivers
  • Bitperfect: Wasapi / Asio for Microsoft XP to Win8
  • Inputs: 1x Optical Toslink, 1x Coaxial, 1x USB B and 1x AES / EBU
  • Decoding up to 32bit / 384kHz (USB) per XMOS interface and 24bit / 192kHz for other digital inputs
  • DSD native support (DSD64 (dop / native), DSD128 (dop / native)
  • Digital isolation of USB and Coaxial inputs
  • 2x high precision clocks CRYSTEK CCHD-957
  • Shielded Toroidal Transformer
  • Stereo analog outputs on RCA and XLR
  • Output Voltage (RCA): 2.8Vrms
  • Output Voltage (XLR): 5.6Vrms
  • Headphone output:
  • 300mW @ 600 Ohm
  • 600mW @ 300 Ohm
  • 1500mW @ 120 Ohm
  • 3000mW @ 32 Ohm
  • Physical characteristics :
  • Selecting sources by pushbutton
  • Volume control for helmet with notched potentiometer
  • Chassis Aluminum Black anti-oxidation treated
  • Non-slip rubber feet
  • Dimensions of the case: 255 x 211.5 x 58mm
  • Weight 2.450kg
  • The bundle contains:
  • A USB cable of 1M50.
  • A mains cable of 1m50
  • A mini CD containing Windows drivers.
AUNE S16
T
is in French(Click here)
Test in French (Click here)
[Img-14664-left-thickbox_default]
aune
aune
aune
aune s16
[Img-11896-left-thickbox_default]
[Img-11897-left-thickbox_default]
Illustration with the file player Aune S18.
3 reviews
Excellent DAC !
Très beau produit bien fini et aux excellentes performances pour un rapport qualité prix étonnant.
Je me suis laissé aller à mettre mes impressions ici : http://laurentiaart.com/WP3/2016/03/dac-aune-s16-les-chinois-font-aussi-de-bons-produits/
This review has been posted for AUNE S16 DAC DSD / DXD AK4495S 32bit / 384kHz XMOS
Ce dac est excellentissime
Ce dac est excellentissime avec des "Tannoy - Reveal 502 Paire + Level Pilot"
en Câbles symétriques XLR.
Magnifique avec les artistes comme "Cecile McLorin Salvant,Cassandra Wilson, Eric Bibb, Eugene Ruffolo,Ayo,Armand Amar,Antonio Farcione & Sabina Sciubba,Allan Taylor,Alison Krauss,Al Di Meola,Hilary Gardner,Joanna Wang,Lee Ritenour,Mara & David,Mark Knopfler,Natalie Merchant,Neil Young,Ottmar Liebert,Passenger,Peder af Ugglas,Rigmor Gustafsson,Sara K.,Spyro Gyra,Steve Strauss,Tsai Chin,Yo-Yo Ma "
J'utilise un Grados SR325 avec la sortie casque.
Foobar2000 v1.2.3 avec les plugins foo_dsd_asio, sacd.
 (3)
 (4)
Belle bête !!! AUNE the road again pour ce DAC!
Avec ce modèle AUNE joue dans la cour des très grands ( déjà au niveau tarif c'est le premier produit de la marque qui passe la barre des 500€ !! et pas seulement en France , il est donc proposé ici à un très bon prix!!!)
Les composants utilisés justifient ce prix ! y a du lourd inside et cela s'entend !!! je ne lui trouve aucun défaut pour l instant . Pas trop analytique , soundstage de ouf ...profondeur et largeur combinées....et placement très précis des instruments ..... faculté de mettre en évidence le travail de l ingénieur du son ! Il rend grâce aux masterings de qualité !
Rien à dire sur les connectiques proposées , c'est là aussi complet ..
Et pour terminer lecture DSD à gogo ! fichiers ISO etc.. il a de l'appétit le bougre et prend tout en natif !
Seul problème le stock et délai à précommander d'urgence si vous voulez être servi.
