CYP DCT-4N ADC Analog to Digital Converter 16Bit 48kHz
Reference : 5391
52,90 €tax incl.
44,08 € tax excl.
This small device allows you to transform a standard analog signal into an optical or coaxial S/PDIF signal. You can switch from one input to the other using the button on the side. You can use this device to transport an analog signal over a long distance without losses, or use an analog source on a device with digital input.
Features:
  • Analog stereo RCA input
  • Optical and coaxial outputs
  • Output frequency: 48kHz
  • Input level: 2Vpp
  • Supply voltage: 5VDC via Jack DC 5.5/2.1mm(power supply included)
  • Dimensions: 42*40*22mm
DAC / ADC ChipNC
Max sampling rate48kHz
ColorWhite
