AUDIOPHONICS MPC6 V2 Power distributor 6 ports Aluminum FURUTECH Silver
4.7 / 5
By buying this product you get 42 loyalty points
Reference : 11583
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 09-10-2026.
    The Audiophonics MPC6 V2 represents the next generation of high-end power strips. The Audiophonics MPC6 V2, with a revised and corrected finish with rounded fingernails and improved mechanical strength, offers great possibilities for optimization.
    This new generation MPC6 V2 features a new aluminum finish with rounded corners for better finishing and increased electromechanical performance.
    Throughout the process of creating this product the emphasis has been placed on the choice of materials so as to obtain one of the best possible interconnections sector.
    Thea connectic is integral of source FURUTECH and processed with the famous Alpha process, the ELECAUDIO wire has been retained for its monocrystalline OCC copper, its PTFE insulation and its very low impedance. The retained tips allow better contact and increased protection against corrosion, aluminum housing has been selected for its massiveness, inertia and robustness.
    Here are the IEC, Schuko, and wiring jacks used for the Audiophonics MPC6 V2:
    Sockets Schuko:
    IEC socket:
    Wiring:
    Chassis Thickness :
    • Facades: 3.5 mm
    • Sides: 3.5 mm
    • Top: 8mm
    • Bottom: 3 mm
    Characteris ics:
    • 6 plugs Schuko FI-E30 Pure gold plated copper
    • IEC FURUTECH FI-06 connector
    • Anti-slip rubber feet
    • Dimensions (in mm): 340 x 123 x 75 (W x W x H)
    • Weight: 2.2kg
    • Silver color
    - Wiring diagram MPC6 V2 -
    Schéma de câblage DISTRIBUTEUR SECTEUR MPC6 V2
    Number of sockets6
    FilteringNo
    6 reviews
    A clear upgrade over ~€200 power distributors
    This is my first star wired power strip/distributor. I have previously used models from Supra, both versions with tinned copper wiring inside and the black models with silver plated copper. I have also used a Ludic Asgard (which I preferred over the Supra distributors). This Audiophonics power strip is head and shoulders better than all the previous distributors I have owned. It definitely sounds more like every device is plugged straight into the wall, ie every device has a more relaxed and effortless delivery of sound. In a normal power strip where devices are wired in series, all the devices interact with each other. I own two iFi AC filters, and if I plug them into the last two sockets on a normal power strip it dramatically affects the sound of the devices placed ahead of it in series. By using a star wired power strip, this interaction is minimized and everything clearly sounds better. I'm talking treble that is not as brittle and more pleasant, much better separation of sounds, and generally a slightly warmer more powerful sound. Basically, a cheaper power strip is a compromise that changes how devices work for the worse, whereas a power strip like this one allows every device plugged into it to work as intended without being affected by other devices plugged into the power distributor. Highly recommended. But why only 4 stars out of 5? Because mine arrived with loose screws inside. I opened it up and could screw them down without issue, and aside from the loose screws the finish and quality was impeccable both inside and out.
    This review has been posted for AUDIOPHONICS MPC6 V2 Power distributor 6 ports Aluminum FURUTECH Silver
    Waiting for MPC6 V3
    Could we get please the same version with FI-09 NCF Rhodium inlet, and FI-E30 Rhodium sockets instead? And upgraded cabling ? Some of us are not a big fan of gold.
    High Quality
    This is better than Furutech's original power distributors. I'd recommend to all of you. Good job!
    High peceived value for money regarding both build quality and sonics. Top customer service with quick replys to pre sale questions and fast delivery after ordering.
    Le Boitier secteur MPC6 sublime
    Le Boitier secteur MPC6 est vraiment top comparé à Furutech Gigawatt mpc audio divers marque comme Actinote est encore BC Acoustique Audioquest Niagara 1000 ce boitier reste dans la course franchement merci
