Our RaspDac allows you to enjoy your dematerialized high-definition music without limit. This model is equipped with an I-Sabre ES9023 DAC.
KEY POINTS:By buying this product you get 19 loyalty points
This product is delivered in kit DIY to be assembled.
We also offer the mounted version here .
DAC I-Sabre V3 Network Reader ES9023 and Raspberry Pi 3
Go to the high definition dematerialized with the RaspDAC. Housing 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, Raspberry 2.0!
Here is an affordable solution of dematerialized reading assembled and tested in our workshops.
Ready-to-use network reader electronically, all you have to do is opt for the software solution of your choice (Volumio, Picoreplayer, Raspbmc, Openelec).
Simply get a high-end digital audio player with a 24bit / 192Khz Bit-Perfect resolution.
AUDIOPHONICS integrates the new DAC I-Sabre V3 ES9023 24 / 192Khz equipped with a TCXO precision clock and a revised and corrected mass circuit, and a new low regulation noise LDO capacitors OS Con, this DAC I-Sabre V3 is the heart of the RaspDAC.
In addition, its advanced ATX-type power management with different extinguishing modes offers a high level of ease of use.
It has all the inputs / outputs necessary for its connector, its power (jack DC 5.5 / 2.1mm), an HDMI port and an OLED display.
Illustration withlinear regulated external power supply 5V 2A not provided
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.Here is the full version assembled and tested in our workshops of our latest Sabre family converter associated with a file player based on a Raspberry PI.
| Specifications | |
| Raspberry Pi 3 | Model B |
| DAC | Audiophonics I-Sabre V3 ES9023 TCXO |
| display | OLED |
| <inputs/ Td>1x RJ45 / 4x USA-A | |
| Exits | 1x HDMI / 1x RCA stereo |
| Food | Jack DC 5.5 / 2.1mm |
| Dimensions | 160 x 140 x 50mm |
| Display Size | 65 x 16mm |
| Weight | 0.9kg |
| Housing material | 100% Aluminum |
| Color | Black |
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2 Model B and Audiophonics DAC I-Sabre V3 ES9023.
Supplied accessories:
To allow you to be directly operational, the player comes with an 8GB SDHC card, and also an external standard 6V 2A power supply on 5.5 / 2.1 connector.
Improve quality (back-up noise reduction) with optional AUDIOPHONICS lineaexternal regulated external double 2x 6V 2.9A 25VA.
