LITE V3310 4ch 4-way or 2-way volume control module XLR
-25%
4.0 / 5
Reduced price!
Reference : 3608
79,00 €tax incl.
-25%
59,25 €tax incl.
49,37 € tax excl.
Shipping date: 17-11-2026.
4-way RCA or 2-way XLR balanced digital volume controller
Complete ready-to-run card set.
For 2 balanced channels the kit includes:
  • A controller card
  • 2 volume control cards
  • A remote control
Each card has an input selector and volume control, which are synchronized by the control board.
Since each card has 4 entries it is possible to connect 4 symmetrical sources to an output 2 attenuated balanced channels.
Ideal for managing the volume of XLR connected devices without dismantling.
Features:/ P>
  • Crystal Semiconductor CS3310 Digital Volume Controller
  • Signal to Noise Ratio 116dB
  • 0.001% THD + N
  • Channel separation 110dB
  • Stabilized power supply on each board (direct supply by toric)
  • Volume -80dB to 0dB + Mute
  • Control by remote control or front button
  • 4 relay selectable inputs (on each board)
  • Display of the selected input and volume
  • Dimensions of the cards:
    Volume: 250x60x26mm
    Control: 230x52x10mm
It remains to add a transformer toric 12VAC and a transformer 9VAC of 15VA as well as the wiring.
Photo of kit:
Cable schematics
https://www.audiophonics.fr/images2/5440/5440_schema_3310.jpg
Example of implementation (6 asymmetric channels):
Example of equipment required for assembly:
This list is not exhaustive, you may need thermo sheath, welding, screws ...
On our model the facade was simply fixed to the double face, which avoids making fixing holes in the facade but does not facilitate the use of the buttons.
InputPCB Connector
InputSolder pad
OutputPCB Connector
OutputSolder pad
Channel2 (Stereo)
Channel4
Ronflette sur sortie carte volume
sur une réalisation en 6 voies XLR (et une seule entrée utilisée) utilisant donc 6 cartes de volume et une carte de commande, il est apparu une légère ronflette à 100 Hz indépendante du réglage volume (donc sur sortie). Pour l'éliminer, une liaison de forte section de toutes des masses analogiques des cartes volume au niveau des condensateurs de filtrage des tensions d'alimentation 12 V s'avère indispensable car, sinon, les masses analogiques n'étant pas, par construction, exactement au même potentiel, provoquent des courants de masse traversant les cartes.
This review has been posted for LITE V3310 4ch 4-way or 2-way volume control module XLR
