AUDIOPHONICS PI-SPC REG Power Management / Power supply for Raspberry Pi
AUDIOPHONICS PI Touch Power Management Module for Raspberry Pi
Raspberry Pi dedicated power management module. This control module with integrated linear regulation allows you to turn on and off your Raspberry Pi cleanly like a family ATX PC.
4.4 / 5
Reference : 11504
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 07-05-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics PI-SPC REG
Power Management / Power Supply for Raspberry Pi
Audiophonics PI-SPC II Module de contrôle / Alimentation linéaire pour Raspberry Pi
This power management module with integrated linear regulation for Raspberry Pi allows you to deliver 5V from a voltage source ranging from 7V to 12V and thus to properly switch your Raspberry Pi on and off like a family ATX PC. Once the button is pressed, the Raspberry Pi is powered and your software solution starts in a classic way. For the shutdown, an order is sent to the system to shut down, before the module cuts off the power supply. An LED output to connect to the button is available to monitor the progress of the different steps of switching the Raspberry Pi on and off.
Push button functions :
  • Raspberry Pi off: Pressing the push button will start the Raspberry Pi
  • Raspberry Pi on: Press > 0.2s and < 4s : Shutdown command, the RPI will shut down after stopping the software solution properly used
  • Raspberry Pi on: Press > 4s : Emergency stop function, immediate shutdown of RPI power (function available without script
Power LED State :
  • LED Off : Raspberry Pi off
  • Slow flashing: Raspberry Pi powered on, software solution started, BOOT OK signal waiting. Reverse operation for shutdown.
  • Fast flashing: Order to reboot sent from the software solution used (soft reboot)
  • Fixed power on: Raspberry Pi on, software solution used correctly started and ready to use (sds.sh launched)
Installing the script
You will find on our github page the indications concerning the manual installation of the script on our forum:
INSTALLATION SCRIPT POWER SUPPLY PI SPC INSTALLATION
heatsink sink for SPCII PI
Managing heat
This module must be mounted on a chassis. If no chassis is available, use a heatsink sink to prevent circuit overheating.
This is particularly true whith higher voltage input (12V).
We recommend using such a dissipator (or equivalent in terms of heat dissipation). You can also mount a 4x5cm aluminum plate (7V) or 15x15cm (12V) to stabilize the system temperature.
The functions of this card are natively supported by the following software solutions: DietPi, Max2Play, piCorePlayer.
Be sure to put thermal paste between the tension regulator and the chassis for better heat dissipation.
Product typePower Management / Power supply for Raspberry Pi
SoftwareSupplied flashed with start and stop management
Power supplyVia Jack DC 5.5/2.1mm or XH 2.54mm connector
LED OutputYes
State LED on PCBYes
OutputsUp to 4 outputs on XH 2.54mm
Supply voltage7V - 9V (Max 12V with good thermal dissipation)
Fixation hole diameter2.5mm
Dimensions50 x 50 x 17mm
Use with Audiophonics Sabre ES9038Q2M
Button and wires not included
pi spc2 9038
Use with Raspberry Pi 2/3/4
Use with DAC Audiophonics I-Sabre ES9018K2M
Exemple de branchement avec DAC Audiophonics I-Sabre TDA1387
7 reviews
nice product, exactly what I was looking for.
works perfectly with the volumio audiophonics on/off plugin.
just a question, there is a connection for an infrared sensor, how does this work? can't find anything about it.
This review has been posted for AUDIOPHONICS PI-SPC REG Power Management / Power supply for Raspberry Pi
excellent power supply.
works perfectly in combination rasberry pi.
Power management with Moode
I bought this module to implement power management for my streamer. It is important to use a good quality cable between the module and Pi. I used 22 AWG cables. M ysetup: Pi 4 2Gb, Moode , PI-SPC II, Meanwell 7.5V 3 A, DAC Topping D10S. Sound is very good. Moode need configuration, but everything clearly described here: https://github.com/audiophonics/Raspberry-pwr-management
I recommend this module.
Powermanagement mit Ropieee
Ich nutze das Modul mit einem entsprechenden Netzteil zusammen mit einem Raspberry Pi3 b+ und Iqaudio DAC. Es funktioniert mit Hilfe dieser Anleitung hervorragend.
https://community.roonlabs.com/t/audiophonics-power-management-add-on/77578
Die stabiler Stromversorgung wirkt sich nach meiner Meinung auch positiv auf die Musikwiedergabe aus
Module performant
Je l'ai acheté pour me faire un RASPTouch maison avec un DAC ES9023 TCXO en V2.1 avec un KODI sous Xbian. Il offre toutes les possibilités nécessaires à l'alimentation de la Pi3 et de l'écran, à condition de veiller à prendre un bloc alimentation assez puissant (n'hésitez pas à prendre un 7.5V - 3A voir 9V-3A ou 12V-3A, sinon vous risquez d'avoir souvent le logo de manque de jus sur la Pi). Sous KODI/XBian la configuration est un peu difficile, car les services ne sont pas toujours pris en compte correctement. L'intégration dans le script de lancement de KODI du script de gestion des boutons résout le problème du bouton clignotant, l'intégration d'un script de coupure dans le script de fermeture de KODI permet de correctement couper la Pi et l'écran.
Nous conseillons plutôt une alimentation 7.5V 3A. Si il y a une chute de tension trop importante dans les câbles qui vont au PI ce qui est souvent le cas si on n'utilise pas du 22/24AWG, il vaut mieux ajuster le trimmer pour que le module fournisse 5.2V. Le fait de rentrer en 7 ou en 12V ne change pas la tension de sortie, mais par contre fait chauffer le régulateur.
Raspberry Pi dedicated power management module. This control module with integrated linear regulation allows you to turn on and off your Raspberry...
