Discover this accessory that will be indispensable, a SATA controller for hard drive and SSD 2.5 ", with possibility of connecting directly your Raspberry Pi 3 or Raspberry Pi 2, as well as a DAC DIY on the latter to offer you a solution 3-in1 high quality.
Everything you need is included to allow you to connect your Raspberry directly: Screws, spacers , XHP wire for power supply, HDMI offset kit, as well as the USB connection for connecting the controller to the Raspberry directly.
This SATA controller will allow you to have your music library very easily, especially via the Raspberry Pi that you can control with your Smartphone. It is plug and play, and works immediately with all OS without any driver required.
A 5V / 4A AC adapter comes with, allowing you to be directly operational.
