Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
This RCA connector 75Ω developed in Japan by Canare assures you a high quality signal. It has a ring to crimp the connector and a central pin machined in the mass and gold plated with high precision.
This Cat 6 Canare RJC6-4P-SFM Ethernet cable integrates 4 pairs of twisted 0.26mm² conductors with double general shielding type SF/UTP. The latter is composed of a strap and a braid which considerably limits the impact of interference on the signal.
This Canare TCD-35D crimping die has been specially manufactured in Sweden for the Canare TC-1 crimping tool. It has 3 holes: 1.92mm / 7.6mm / 5.85mm. It is perfectly matched to the following Canare connectors: BP-C3, BP-C4, BP-C5, TNP-C3, TNP-C4, TNP-C5, RCAP-C3GS.
Canare's TS100E cable stripper has been specially developed to work with the brand's coaxial cables. This machine has 5 default settings and you can create your own settings. To find out the exact dimensions of each compatible Canare cable, please refer to the user manual.
Canare's TS100H cable stripper has been specially developed to work with the brand's coaxial cables. This machine has 5 default settings and you can create your own settings. To find out the exact dimensions of each compatible Canare cable, please refer to the user manual.
Canare's TS100U cable stripper has been specially developed to work with the brand's coaxial cables. This machine has 5 default settings and you can create your own settings. To find out the exact dimensions of each compatible Canare cable, please refer to the user manual.
Canare's TSC replacement blade is designed for use with the TS100E and TS100U coaxial cable strippers, allowing you to restore the tools' full cutting power.
