At the heart of DIY audio innovation is IAN CANADA, a name synonymous with quality, performance and a passion for high-fidelity audio. This proudly Canadian brand is dedicated to the design and manufacture of audio electronics for DIY (Do It Yourself) enthusiasts and HiFi lovers. For IAN CANADA, every product is the result of meticulous engineering and design with audiophiles in mind. Whether you want to build your own audio system or upgrade an existing HiFi system, IAN CANADA solutions offer an uncompromising audio experience. The catalogue includes a variety of components and modules, all designed to offer exceptional sound clarity, reproduction accuracy and durability. One of IAN CANADA's philosophies is simple: make audio excellence accessible to all. Their products are designed to be easily assembled, offering a rewarding experience for audio DIY enthusiasts. Whether you're a passionate beginner or an audio expert, you'll find in their products the perfect balance between DIY challenge and professional audio quality.
Ian Canada's ReceiverPi Pro II is designed for Raspberry Pi-based DDC or DAC projects, to retrieve a digital audio stream from multiple sources rather than from the Raspberry Pi itself. The ReceiverPi Pro II can select a digital signal from any of the following inputs: coaxial, Toslink optical, I2S via HDMI or Raspberry Pi GPIO.
Ian Canada's ReceiverPi Pro is designed to fit Raspberry Pi based DACs and streamers and allows to extend their input connectivity. The module provides coaxial SPDIF, Toslink optical and I2S via HDMI while being able to receive the stream directly from the Raspberry Pi via GPIO.
Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous mode to improve I2S/DSD signal quality.
Ian Canada's SC-Pure is a high-end audiophile clock made from high-quality SC-CUT crystals. An advanced oscillator architecture has been developed to achieve the best performance in terms of phase noise. Sound quality can thus be significantly improved by replacing a conventional clock with an SC-Pure in DACs or network players, for example.
Ian Canada's ShieldPi Pro MKIII is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO extender/multiplier. The IR remote control function can also be implemented if the module is used with a MonitorPi (sold separately).
The Ian Canada SinePi is a low jitter dual input sine to square wave conversion module that allows an external high performance clock oscillator to be adapted to the FifoPi. The SinePi uses an architecture and topology specifically designed to maintain signal integrity and ensure very low additional jitter.
This SMT XO kit from Ian Canada includes five PCBs and the necessary components to mount XO clocks. These brackets allow the XO clocks to be adapted to certain audio modules that have the necessary connections.
Ian Canada's StationPi Pro is designed to integrate with a Raspberry Pi for audio applications. It can optimize digital audio projects, such as interfaces or DACs, for a perfectly organized and well-finished assembly. It can also provide a slight improvement in audio performance by limiting EMI noise.
The Ian Canada StationPi SMT PCB adapter kit has been designed to enable easier module integration with the Raspberry Pi or other digital music sources. It can help optimize digital audio projects, such as digital interfaces or DACs, for perfectly organized, well-finished assembly. It can also improve sound performance by limiting EMI noise.
The ON/OFF switch by Ian Canada comes complete with mounting nut and washers. Can be connected directly to a LinearPi to make it as a master to start a whole ON/OFF control chain. A PH2.0 2Pin 15cm control cable is supplied. Can also be used to control the ON/OFF of other power supplies, but may need to cut one end of the cable and solder the...
The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply. This module makes it possible to design an excellent, low-cost DAC.
Ian Canada's TransportPi AES is an AES/EBU and SPDIF digital interface board. It is the first model to use a 1bit 50Mbps differential driver and a dedicated femtosecond clock to achieve the highest possible signal quality and very low noise for both AES/EBU and SPDIF outputs.
With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a high-quality signal with very low jitter and noise thanks to Ian Canada's proprietary 3-stage 1-bit discrete reclocking technology for SPDIF signals, and 2-stage multi-bit technology...
The TransportPi Digi is a high performance all-in-one digital audio interface for the Raspberry Pi. It provides ultra-low jitter and low noise signal quality using IAN CANADA's proprietary 3-stage 1-bit discrete reclocking technology for SPDIF signals, and 2-stage multi-bit for I2S signals.
The Ian Canada TransportPi MKII module is a low jitter digital audio interface compatible with the Raspberry Pi. It has been specifically designed in pure synchronous mode to achieve the best jitter performance. When combined with a Raspberry Pi and a FifoPi (sold separately), it creates an audiophile digital interface for Roon or other playback software....
The Ian Canada UcAdapter is a printed circuit board that accommodates the UcMateConditioner and UcHybrid signal conditioner modules and can be easily mounted above the Ian Canada LifePO4 MKII / MKIII power supply using the supplied screws and spacers.
The Ian Canada UcBalancer is a professional supercapacitor protection module specially designed to ensure that 3000F+ supercapacitors work perfectly with UcPure or other high-performance power supplies. Thanks to its high-quality design and engineering, the UcBalancer makes it possible to design power supplies with very low noise and ESR.
The UcConditioner 3.3V is a ultra capacitor signal conditioner board operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
The Ian Canada UcConditioner Pro 3.3V is a ultra capacitor signal conditioner module for use with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
The UcHybrid is a 3.3V signal conditioner module specifically designed to operate with a single battery from the LifePO4 power supply. It improves the quality of the LifePO4 power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
The UcMateConditioner 5V is an ultra capacitor signal conditioner module specifically designed for the Ian Canada LifePO4 MKII and MKIII power supplies. It significantly improves the quality of the 5V power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
Ian Canada's UcPi 2025 is a high performance and affordable 5V supercapacitor power supply module designed specifically for audio applications using a Raspberry Pi to get the best possible sound quality from a clean and stable power signal. The module uses spring contacts to power the Raspberry Pi via its GPIO connector, making installation quick and easy.
UcPure MkIII is a pure ultracapacitor power supply. It uses the 3000F or above capacity ultracapacitor pack to achieve ultimate power performance. Because this is a purely passive power supply, there will be no feedback and no active components are involved when turned on. In pure output mode, only the pre-charged ultracapacitor pack will be applied to...
Ian Canada's UcPure is a supercapacitor power module. It uses large supercapacitors of 3000F to provide a high-performance power supply. It is a totally passive module, with no feedback and no active components. In pure output mode, only the set of pre-charged supercapacitors is applied to the load.
