Bernard B.
fiio BTR 17
Pas d'ataptateur secteur...
Laurent G.
Petit mais super efficace !!
Alain S.
Vous...
List of products Triangle HiFi
The Art of French Sound
Triangle is a company composed of a team of passionate engineers and technicians who have been developing, designing and assembling high-fidelity loudspeakers for almost 40 years in France. The brand claims the importance of a detailed and clear sound allowing to perceive the richness and the subtlety of the musical works. Triangle reinvents itself every day to offer music lovers uncompromising sound reproduction.
The brand's sound is based on dynamic loudspeakers capable of revealing the emotion and feeling of a concert. Triangle has always favored research and technological innovation in order to offer audiophiles a natural and faithful sound of the highest quality.
The components are designed and developed in the brand's research and development center in France. Developed by a team of enthusiasts, Triangle speakers are absolutely unique.
  • Ref : 19612
    The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio.
    390,00 € 325,00 €Ex.
    In Stock
  • Ref : 19611
    In Stock
  • Ref : 19609
    In Stock
  • Ref : 15990
    In Stock
    Developed by Triangle, Opera speaker cables guarantee excellent electrical signal transmission quality. To achieve this, they incorporate braided OFC copper conductors, each insulated with a transparent PVC sheath.
    2,99 € 2,49 €Ex.
    In Stock
  • Ref : 15991
    In Stock
    4,60 € 3,83 €Ex.
    In Stock
  • Ref : 15995
    The Triangle S01 speaker stands have been designed to allow you to position your bookshelf speakers in the best possible way. With a height of 60cm, they bring the speakers to ear level, in a sitting position, so you can enjoy all the nuances of your sound system.
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 17916
    Reduced price!
    In Stock
    Triangle has designed the S02 stands to enable you to position your speakers optimally, meaning with the tweeter 90cm above the floor, which corresponds to your ear height when seated. This will enable you to enjoy the full richness of the sound delivered by your Hi-Fi system. The top shelf of the S02 measures 16.5 x 21.5...
    98,69 € 82,24 €Ex.
    139,00 € In Stock
  • Ref : 19004
    Triangle S05 speaker stands are designed for bookshelf models. They provide excellent stability and optimal speaker positioning. With a height of 62cm, the Triangle S05 speaker stands enable you to place your speakers at ear height for optimum diffusion of your music.
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 19001
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 19002
    In Stock
  • Ref : 19005
    In Stock
  • Ref : 19006
    Triangle's Stand Filler ballast increases the weight of speaker stands by integrating them into the tube or base. Made from high-density metal micro-cylinders, these balls add weight to the stands, further reducing the vibrations generated by the loudspeakers, while minimizing the risk of resonance.
    59,00 € 49,17 €Ex.
    In Stock
  • Ref : 15996
    In Stock
    The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors made of 99.99% pure OFHC copper, ensuring optimal electrical conductivity.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 15997
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 15998
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 16482
    The Triangle Tales 340 active subwoofer is versatile and can be integrated into a HiFi or Home Theater installation. This one is equipped with a 25cm diameter loudspeaker with a long travel and a Class D amplifier allowing it to deliver a power of 200W RMS (350W max). It will enable you to bring to a stereo system a beautiful base in the bass as well as a...
    In Stock
  • Ref : 16484
    In Stock
  • Limited special offer
    Ref : 16483
    Reduced price!
    351,00 € 292,50 €Ex.
    390,00 € In Stock
    Ref : 16602
    Reduced price!
    In Stock
    Triangle offers a beautiful manual vinyl turntable with belt drive. This one has been specifically developed by the famous Pro-Ject brand and allows the playback of 33 and 45 rpm records. Its straight aluminum arm and its low vibration motor ensure a smooth and flawless playback. The arm as well as the Ortofon 0M-10E cell are pre-set for a quick and easy...
    349,00 € 290,84 €Ex.
    399,00 € In Stock
