Pack Topping D900 DAC + A900 Headphone Amplifier / Preamplifier + TCX1 XLR Cables 25cm
This Topping pack, comprising the D900 DAC, the A900 headphone amplifier and preamplifier, and a pair of 25cm TCX1 XLR cables, will enable you to enjoy exceptional sound quality, both on headphones and in classic integration with a power amplifier.
By buying this product you get 274 loyalty points
Reference : 20966
2 749,00 €tax incl.
2 290,83 € tax excl.
Pack content
Pack Topping D900 + A900 + TCX1 DAC + Headphone Amplifier / Preamplifier + XLR Cables 25cm
Topping D900: An exceptional, discrete DAC
The Topping D900 pushes the boundaries of audio fidelity with an exclusive 32-phase DSM (Discrete Sigma Modulation) architecture. A true showcase of Topping's technological know-how, this top-of-the-range DAC combines digital precision, organic musicality and total flexibility to sublimate all your sources. It supports high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. Its digital-to-analog conversion stage is supported by an Altera Max II CPLD and Accusilicon 45MHz/49MHz clocks, guaranteeing perfect synchronization.
Numerous features are available, such as Bluetooth 5.1 supporting LDAC and a 10-band parametric equalizer accessible via the Topping Tune application. As far as connectivity is concerned, the Topping D900 is very complete, with numerous digital inputs enabling it to adapt to a wide range of configurations. Outputs include two balanced XLR outputs: a line output and a preamplifier output, offering versatility for integration into your audio system.
Product updated to firmware V1.29.
Find out more about Topping D900
Topping D900
Topping A900: A high-performance, versatile headphone amplifier and preamplifier
The Topping A900 is a high-end headphone amplifier and preamplifier, combining power, performance and design. It benefits from T'ang-ku-la's proprietary symmetrical amplification architecture, enabling it to develop significant power, making it capable of accompanying the vast majority of audio headphones. What's more, in addition to its exceptional measurements, the A900 boasts a particularly comprehensive connectivity package to meet a wide range of needs.
Learn more about Topping A900
Topping A900
Topping TCX1: XLR Cables 25cm
Topping's TCX1 cables are high-quality XLR male/female cables. They feature 6N copper and 6N silver-plated copper conductors for perfect signal transmission. Each conductor has a cross-section of 0.533mm² (19AWG). Connector contacts are gold-plated for excellent conductivity and resistance to oxidation. Each cable is covered by a robust black and red braided nylon sheath.
Learn more about Topping TCX1
Topping TCX1
Products typeDAC + Headphone amplifier / Preamplifier + XLR cables
Pack content1x Topping D900
1x Topping A900
1x Topping TCX1 XLR cables pair 25cm
Topping D900 general specifications
DAC chipPSRM
Bluetooth chipQCC5125
CPLDAltera Max II
Inputs1x USB-C
1x USB-B
2x Coaxial
2x Optical
1x AES/EBU
1x I2S via HDMI
Bluetooth
Outputs1x XLR line out
1x XLR preamp out
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
ColorSilver
Accessories1x Bluetooth remote control
1x Bluetooth antenna
1x Power cable
Topping A900 general specifications
Inputs3x Combo XLR (balanced) / Jack 6.35mm (single-ended)
Outputs2x Combo XLR (balanced) / Jack 6.35mm (single-ended) headphone output
2x Balanced XLR 4 pins headphone output
2x Balanced Jack 4.4mm headphone output
1x Balanced XLR pre-out
Headphone output power (single-ended output)2x 6000mW @ 16Ω, THD+N <0.1%
2x 3000mW @ 32Ω, THD+N <0.1%
2x 1550mW @ 64Ω, THD+N <0.1%
2x 660mW @ 150Ω, THD+N <0.1%
2x 330mW @ 300Ω, THD+N <0.1%
2x 165mW @ 600Ω, THD+N <0.1%
Headphone output power (Balanced output)2x 22000mW @ 16Ω, THD+N <0.1%
2x 14000mW @ 32Ω, THD+N <0.1%
2x 7000mW @ 64Ω, THD+N <0.1%
2x 3000mW @ 150Ω, THD+N <0.1%
2x 1500mW @ 300Ω, THD+N <0.1%
2x 750mW @ 600Ω, THD+N <0.1%
ColorSilver
Accessories1x Remote control
1x Power cable
Topping TCX1 general specifications
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable outer diameterØ8mm
Conductors materialCopper
Silver plated copper
Conductors section0.533mm² (19AWG)
Contacts platingGold
Outer sheathBraided nylon
ColorBlack and red
QuantityPair
This Topping pack, comprising the D900 DAC, the A900 headphone amplifier and preamplifier, and a pair of 25cm TCX1 XLR cables, will enable you to...
