This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any surface. However, two holes allow the fastener to be screwed in for a firmer hold.
These adhesive cable ties simply attach to a wall to allow you to group your cables together. The base of the cable ties is adhesive and can be easily attached to any surface. Two holes allow you to screw the clips for a firmer hold.
This discrete voltage regulator has been designed to replace an LM7812 IC model (or LM7815 / 7818 / 7824 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +12V is adjustable in the range +12V to +25V by means of a potentiometer. This controller provides low ripple, low noise and fast response.
This discrete voltage regulator has been designed to replace an LM7912 integrated circuit model (or LM7915 / 7918 / 7924 with pre-setting), in order to provide your audio system with a cleaner electrical signal. Its value of -12V is adjustable in the range -12V to -25V by means of a potentiometer.
This extension consists of a male Micro SD connector and a female Micro SD reader. The female connector opens and allows you to effectively lock your Micro SD card inside.
This USB cable consists of a female USB-A connector and a male Micro USB connector. Particularly flat, this cable benefits from a beautiful design quality with tinned copper conductors with a section of 0.0509mm² and 0.0810mm², each being insulated by a PE sheath and then covered with an external TPE sheath.
This USB cable consists of a male USB-A connector and a male Micro USB connector. Particularly flat, this cable benefits from a beautiful design quality with tinned copper conductors with a section of 0.0509mm² and 0.0810mm², each being insulated by a PE sheath and then covered with an external TPE sheath.
This AG12 button cell (other names: LR43, LR1142, 386) will allow you to power small devices requiring this type of battery. This one delivers a voltage of 1.5V and a current of 100mAh.
This small 10x10x10x10mm Aluminum heat sink is ideal for efficiently evacuating the heat released by an electronic component. Its assembly is simple and quick thanks to its adhesive pad.
This small 14x14x7mm Aluminum heat sink is ideal for efficiently dissipating heat from an electronic component. Its assembly is simple and quick thanks to its adhesive pad.
This small 20x20x10mm Aluminum heat sink is ideal for efficiently dissipating heat from an electronic component. Its assembly is simple and quick thanks to its adhesive pad.
This small 9x9x5mm Aluminum heat sink is ideal for efficiently evacuating the heat released by an electronic component. Its assembly is simple and quick thanks to its adhesive pad.
This sturdy black aluminium knob has a diameter of 25mm. It can be easily fixed on the flat axis of a potentiometer or attenuator with a hexagon screw and will contribute to give your camera a sober and modern aesthetic.
This silver-coloured Aluminium stand effectively limits the vibrations suffered by your devices thanks to a rubber ring that absorbs and prevents them from slipping.
This black Aluminium stand for HiFi devices will allow you to bring stability and shock absorption to your system, which is equipped with a rubber washer.
