DAYTON AUDIO 4K-HPF-4 Speaker High Pass Filter
New
Dayton Audio filters make it easy to limit the frequency response of a speaker to a desired frequency band. By using a combination of different Dayton Audio filters you can create complete 2 or 3-way crossovers.
Reference : 22661
14,90 €tax incl.
12,42 € tax excl.
Dayton Audio 4K-HPF-4
Speaker High Pass Filter 4000Hz 12dB/Octave 4 Ohm
This 12dB/Octave 4000Hz high-pass filter can be combined with a Dayton Audio 4000Hz low-pass filter to create a Linkwitz-Riley crossover. It is also possible to shift or overlap filter frequencies to compensate for peaks and valleys in the frequency response of each speaker.
Product typeHigh Pass filter
Frequency4000Hz
Impedance4Ω
Power handling250W
Capacitor value5µF
Inductor value0.32mH
Dimensions100 x 60mm
Impedance (Ω)4
DAYTON AUDIO 4K-HPF-4 Speaker High Pass Filter 4000Hz 12dB/Octave 4 Ohm
Dayton Audio filters make it easy to limit the frequency response of a speaker to a desired frequency band. By using a combination of different...
