The FiiO Snowsky Wind Pro is a wired on-ear headphone with a semi-open design and retro styling. Its 40mm dynamic driver, combined with a bass response specified down to 23Hz, relies on vents and damping filters to preserve an open presentation while limiting sound leakage.
Designed for portable use, it combines a weight of approximately 77g, an adjustable headband and swiveling earcups to adapt the fit to each user. The version with a 3.5mm jack cable features in-line controls.
The FiiO Snowsky Wind Pro takes up the codes of compact retro headphones in a design intended for everyday listening. Building on the acoustic approach of the EH11, it combines an on-ear format with a 40mm dynamic driver, with a bass response specified down to 23Hz. The reinforced cabling and earcups with a metallic finish, produced by vacuum metallization, complete a compact, easy-to-carry design with styling inspired by the 2000s.
The Wind Pro combines a semi-open design with vents and acoustic damping filters to promote extended treble and natural vocals while limiting the feeling of confinement. This architecture reduces sound leakage compared to a fully open headphone, without completely isolating the listener from their surroundings. Its 40mm dynamic driver uses a flexible composite suspension that limits resonances, contributing to present bass, precise impact and a detailed soundstage.
Weighing approximately 77g, the Wind Pro limits pressure during long listening sessions. Its stainless steel headband is adjustable, while the swiveling earcups adapt to the user's head shape for a personalized fit. On the version equipped with a 3.5mm jack cable, the in-line controls allow you to manage playback, select tracks and adjust the volume; compatible with the CTIA standard, they work with most audio devices supporting this standard.
Technical specifications
| Specifications | |
| Product type | Headphone |
| Headphone type | Semi-open on-ear |
| Driver | Dynamic Ø40mm |
| Frequency response | 23Hz-20kHz |
| Sensitivity | 100dB |
| Impedance | 16Ω |
| Cable length | 1.2m |
| Cable termination | 3.5mm jack |
| Detachable cable | |
| General | |
| Weight | 77g |
| Color | Black |
| Package | 1x FiiO Snowsky Wind Pro 2x Black foam ear pads 2x Grey foam ear pads |
| Color | Black |
| Impedance (Ω) | 16 |
| Efficiency / Sensitivity (dB) | 100.0 |
| Lowest frequency (Hz) | 23 |
| Highest frequency (Hz) | 20000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | NC |
