FIIO SNOWSKY NATURE Headphone
New
The FiiO Snowsky Nature is a wired over-ear headphone fitted with a 50 mm dynamic driver featuring a Japanese black carbon composite diaphragm. Its structure combines a 19 µm PET base with a 30 µm TPU layer to limit resonance and distortion while preserving detailed reproduction.
Reference : 22654
44,90 €tax incl.
37,42 € tax excl.
FiiO Snowsky Nature Dynamic Headphone 50mm 24 Ohms 101dB 20Hz-40kHz Black
FIIO SNOWSKY NATURE: Front view
The FiiO Snowsky Nature is a wired over-ear headphone fitted with a 50mm dynamic driver featuring a Japanese black carbon composite diaphragm. Its structure combines a 19µm PET base with a 30µm TPU layer to limit resonance and distortion while preserving detailed reproduction.
Its low impedance and high sensitivity make it easy to use with a smartphone or portable audio player, without requiring dedicated amplification. The detachable cable with dual 3.5mm jacks allows a choice between unbalanced and balanced connection, while the microphone and remote control built into the supplied cable extend its use to calls and playback control.
FiiO Snowsky Nature: 50mm driver with composite diaphragm
The Nature features a 50mm dynamic driver with a Japanese black carbon diaphragm. Its structure combines a 19µm PET base with a 30µm TPU layer to balance rigidity and vibration damping. This design aims to reduce distortion and coloration while preserving stable reproduction, articulate bass and a detailed soundstage.
FIIO SNOWSKY NATURE: Driver
FiiO Snowsky Nature: Controlled reproduction
A high-strength magnet and a copper voice coil work together with the driver to ensure a linear and stable response. This configuration promotes transient control and limits distortion, from the most subtle passages to larger dynamic swings. Its low impedance and high sensitivity allow it to be used with common sources such as a smartphone or portable audio player, while a portable USB DAC/amplifier can complement the setup.
FIIO SNOWSKY NATURE: Frequency response
FiiO Snowsky Nature: Detachable cable
The headphone uses a dual 3.5mm jack connection, compatible with unbalanced or balanced cables. The supplied cable features an in-line microphone and remote control, allowing it to be used for everyday listening or calls. Track controls depend on the compatibility of the source device; on iOS, a single press plays or pauses playback, while two or three presses change tracks.
Technical specifications
Product typeHeadphone
Headphone typeClosed-back
DriverDynamic Ø50mm
Frequency response20Hz-40kHz
Sensitivity101dB
Impedance24Ω
Headphone connectors3.5mm jack
Cable length1.5m
Cable termination3.5mm jack
Detachable cable
Weight280g
Package1x FiiO Snowsky Nature
1x 3.5mm jack cable
1x Storage pouch
Impedance (Ω)24
Efficiency / Sensitivity (dB)101.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
FIIO SNOWSKY NATURE Dynamic Headphone 50mm 24 Ohms 101dB 20Hz-40kHz Black
The FiiO Snowsky Nature is a wired over-ear headphone fitted with a 50 mm dynamic driver featuring a Japanese black carbon composite diaphragm. Its...
