OEAudio MMCX male connector CuOFP Gold Plated (pair)
OEAudio MMCX connector CuOFP Gold Plated
Reference : 14136
19,08 €tax excl.
Including 0,04 € for green tax
Shipping date: 19-10-2021.
Orders placed before 11AM (GMT+1) will generally be shipped the same day (working day).
Shipping from France
Billing in France
Technical support in France
MMCX Connector for IEM
This MMCX connector is ideal for the construction, repair or improvement of your EMI cables. It has a high conductivity CuOFP with gold plating & anti-oxidation treatment.
Each pin is insulated by an LCP housing (liquid crystal-polymer) which eliminates interference between the signal pin and ground pin.
The outer housing is made of the same material, thereby limiting as well external disturbances. The latter is composed of two clip-facets, allowing assembly after welding for more convenience.
TypeMMCX connector
Contactsx2
Oxygen-Free Gold-Plated Phosphorus Copper
HousingLCP
to clip
Internal diameter⌀3.5 mm
Length10.5 mm
PlatingGold
Package Contents
Connectors CIEMx2
Semi-housings connectors to assemblex4
PlatingGold
Max cable diameter (mm)3.5
Mounting typeTo weld
ConnecticMale
Contacts number2
ConnectorMMCX
Colissimo - TNT - SoColissimo
