By buying this product you get 319 loyalty points
The Tonewinner SW-D8000PRO active subwoofer is a bass reflex subwoofer equipped with two 38.1cm drivers for an RMS power of 1500W under 3Ω, and can reach 8000W at peak. It offers numerous options such as crossover frequency adjustment, 7-band equalisation, volume control and 0°-180° phase inversion. Six vents on the front panel improve bass response. In terms of inputs, you can choose between an RCA line input or two other inputs: single-ended RCA LFE and balanced XLR. Furthermore, the SW-D8000PRO also offers an LFE output.
In order to deliver powerful bass, the SW-D8000PRO has been equipped with two 38.1cm diameter drivers, each coupled with a 75mm voice coil and a dual magnet circuit. This configuration allows you to get the most out of the 1500W Class D amplification, ensuring powerful and dynamic bass reproduction, capable of reaching frequencies as low as 12Hz.
Thanks to the Tonewinner app available on Android and iOS, the SW-D8000PRO offers 7-band equalisation settings, crossover frequency adjustment and phase inversion, allowing you to perfectly tailor your subwoofer's performance to your listening environment and usage.
| 1 | Power supply voltage switch |
| 2 | Power switch |
| 3 | Power supply socket |
| 4 | Fuse |
| 5 | Sub XLR input |
| 6 | Sub RCA input |
| 7 | Sub output |
| 8 | RCA line input |
| 9 | Volume control |
| 10 | Mute function / Confirm button |
| 11 | Menu button |
| 12 | LCD screen |
| Specifications | |
| Product type | Active subwoofer |
| Driver diameter | 2x Ø38.1cm |
| Amplification type | Class D |
| Output power | RMS : 1500W Max : 8000W |
| Frequency response | 12Hz - 220Hz |
| Phase adjustment | 0 - 180° |
| Impedance | 3Ω |
| DSP / EQ | |
| Inputs | 1x LFE XLR 1x LFE RCA 1x RCA stereo line input |
| Output | 1x RCA LFE output |
| General | |
| Dimensions | 930 x 612 x 650mm |
| Weight | 85kg |
| Color | Black |
| Package | Sold by unit |
