This product has been replaced by the new version, the 3E AUDIO PFFB Balanced Class D Amplifier Module TPA3255 BTL.
Stereo Class D TPA3255 2x 225W 4 Ohm
This stereo amplifier module integrates a TPA3255 amplifier chip, allowing it to develop a consequent power of 2x 225W under 4Ω (1% THD+N) while taking advantage of the high efficiency inherent to its Class D architecture. The careful design of the module allows it to display very good measurements, such as a background noise of 85µVrms or a dynamic range of 111dBA.
The two inputs, on 3 pin 2.54mm connectors, can operate balanced or unbalanced, via a jumper adjustment. An auxiliary power supply output is also available, delivering 12V 0.2A, allowing to supply a preamplifier module.
The module may only be powered via a power supply input. Never connect both power inputs simultaneously.
| Specifications | |
| Revision | B |
| Product type | Amplification module |
| Amplification chip | 1x TPA3255 |
| Amplification type | Class D |
| Channels | Stereo (2) |
| Power output | 2x 225W @ 4Ω, THD+N 1% 2x 280W @ 4Ω, THD+N 10% |
| Input | 2x 3 pins 2.54mm connectors (switch balanced/single-ended) |
| Outputs | Speaker terminals |
| Auxiliary power supply output | 12V 0.2A |
| Speakers impedance | 4Ω ~ 8Ω |
| Dynamic range | 111dBA |
| Possible configuration | BTL / PBTL |
| Noise floor | 85µV |
| Supply voltage | 24V ~ 48V |
| Dimensions | External : 105x90mm Distance between centres: 97x82mm Maximum height: 40mm |
| Input | PCB Connector |
| Output | Screw terminals |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3255 |
| Power (W) | 225.0 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lennart H.
