This Class D stereo amplifier module is based on an Infineon MA5332M amplifier chip. It can deliver 2x125W at 4 Ohm, or 2x65W at 8 Ohm. A heatsink is fitted to the MA5332 chip for efficient heat dissipation. For signal input, the module accepts an single-ended stereo RCA input, via two 2-pin PCB connectors. The module's power supply accepts a range from 200 to 240V AC. Furthermore, this Class D amplifier module can be used to power other modules, such as a DAC, thanks to several power supply outputs: respectively a -/+ 12V 300MA output, a +38V 200MA output, and a +5V 1A output.
| Specifications | |
| Product type | Class D stereo amplifier module |
| Amplification chip | Infineon MA5332M |
| Input | 1x Single-ended RCA stereo input on PCB connector |
| Ouputs | 2x125W @ 4Ω, 0.1% THD+N 2x65W @ 8Ω, 0.1% THD+N |
| Additional connectors | +/-12V 300MA power supply output +38V 200MA power supply output +5V 1A power supply output |
| Signal-to-noise ratio (SNR) | 90 dB |
| Power supply | 200V - 240V AC |
| General | |
| Dimensions | 250 x 80 x 40 mm |
| Mounting holes | 245 x 65 mm |
| Weight | 515g |
| Package | 1x MA5332M class D stereo amplifier module |
| Input | PCB Connector |
| Input | RCA |
| Output | Speaker terminal |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Infineon MA5332M |
| Power (W) | 125.0 |
