ARYLIC UP2STREAM AMP SUB Amplifier Board Subwoofer WiFi 60W 4 Ohm
20%
The Arylic Up2Stream AMP SUB module allows you to add a subwoofer to your stereo system to enjoy deeper bass. Able to develop a power of 100W, its frequency range is also adjustable from 10Hz to 300Hz.
Reduced price!
Reference : 14996
Limited time offer:
105,00 €tax incl.
-20%
84,00 €tax incl.
70,00 € tax excl.
Last items in stock !
Shipping date: 08-07-2025.
Arylic Up2Stream Amp Sub
Arylic Up2Stream Amp Sub Module Amplificateur Subwoofer WiFi 60W 4Ω
The Arylic Up2Stream AMP SUB module allows you to add a subwoofer to your stereo system to enjoy deeper bass. Able to develop a power of 100W, its frequency range is also adjustable from 10Hz to 300Hz. It is also possible to add several subwoofers to your audio system, by grouping several AMP SUB to your stereo module. The module is compatible with WiFi, AirPlay, UpNP and DLNA transmission protocols. Finally, the free 4Stream mobile application allows you to easily manage playback on the different Up2Stream systems in your home.
Application mobile Android Play Store Application mobile iOS App Store
Product typeSubwoofer amplifier WiFi
WiFi networkIEEE 802.11b/g/n 2.4G
InputsWiFi
Jack 3.5mm
OutputSpeaker terminal
Frequency response10Hz - 300Hz
Power output100W @ 2Ω, 24V
60W @ 4Ω, 24V
30W @ 8Ω, 24V
THD0.1% @ 100Hz / 1W
Recommended speaker impedance2-8Ω
Transmission protocolsAirPlay
DLNA
UPnP
Spotify Connect
QPlay
Dimensions84 x 84 x 17.5mm
InputWiFi
InputJack 3.5mm
Channel1 (Mono)
Amplifier chipN/A
Power (W)60.0
The Arylic Up2Stream AMP SUB module allows you to add a subwoofer to your stereo system to enjoy deeper bass. Able to develop a power of 100W, its...
