This Connex kit, comprising a 500W Class D CxD500 Mono amplifier rated at 4 ohms and its switch-mode power supply SMPS600RXE, gives you a solid base for all your powerful amplification needs. Based on the IR2092S controller and IRFB4227 MOSFET transistors, this amplifier delivers impressive power in a compact package. A built-in anti-"ploc" system enables the module to be switched on and off silently. It is necessary to attach the aluminum heat sink to the housing to improve dissipation.
This module requires a DC supply voltage in the range +-62V to +-86V for the power stage, a DC input voltage of +-18 to +-28V 20-30mA for the input stage and a separate voltage, referenced to V- with value in the range 16V to 25V at 40-50mA for the driver stage. The appropriate power supply for a CxD500 amplifier module to obtain 500W power at 4 ohms is the SMPS600RXE module from CONNEX.
The Connex SMPS600RXE switch mode power supply is a very high-efficiency model capable of developing a nominal power of 600W in an extremely small footprint. The SMPS600RXE incorporates overcurrent protection which limits the output current to around 120% of the maximum peak power (760W), equivalent to around 800W. The version supplied is +/- 72 V. It also features a low-consumption differential output, +-24V at 200mA, and a low-consumption 24V 300mA output.
The main feature of this power supply is the absence of heat sinks for both power switches and rectifier diodes. The amount of EMI is lower than any conventional power supply, and could be compared to a linear regulated power supply.
1 | HP output on phoenix connector |
2 | Main power input on phoenix connector |
3 | Micro JST 1.25mm 8-pin secondary power input |
4 | Audio signal input XH 2.54 7-pin connector |
5 | Secondary power outputs AUX 1/AUX 2 Micro JST 1.25mm 8 pins |
6 | Main supply output +/- 72V |
7 | Power supply input |
8 | Selection jumper 230V to 120V |
Product type | Kit CxD500 amplifier module + SMPS600RXE power supply module |
CxD500 amplifier module | |
Channels | Mono (1) |
Amplification type | Class D |
Inputs | 1x Audio input PCB connector XH2.54 7pins 1x Power supply input 3-contact phoenix terminal block 1x Micro JST 1.54mm secondary power input |
Output | 1x HP output phoenix terminal block 2 contacts |
Controller | IRS2092S |
Transistors | IRFB4227 (MOSFET) |
Power | 500W @ 4Ω |
Dimensions | 100 x 40 x 35mm |
Mounting holes | 32 x 92 mm (M3) |
Weight | Approx. 0.11kg |
Protection | Overcurrent / overvoltage / undervoltage / overtemperature |
SMPS600RXE POWER MODULE | |
Input voltage range | 120V or 230V AC (supplied in 230V, 120V selection jumper on PCB) |
Input | 1x Power supply input 120V / 230V |
Outputs | 1x Main power supply output +/- 72V 1x AUX 1 / AUX 2 Micro JST 1.25mm 8 pins secondary power outputs |
Nominal power | 600W |
Maximum power | 760W |
Output voltage | +/- 72V |
Auxiliary output voltage and current | +/- 24V 200mA 24V300mA |
Weight | Approx. 0.5kg |
Input | XH 2.54mm |
Input | PCB Connector |
Output | Phoenix connector |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Transistors |
Power (W) | 500.0 |
