Class D Amplifier Board IRS2092S 2x200W 4 Ohm
The Connex IRS2200SMPS is a Class D amplifier module with integrated power supply. It is based on two IRS2092S chips (one per channel) to deliver a power of 2x200W under 4Ω (THD < 0.1%) or 2x115W under 8Ω (THD < 0.1%), with a high efficiency of more than 94%. It need to be supplied in 230V and has an efficient regulation. The power supply stage of the module ensures a stable and isolated electrical signal for the amplifier.
The input stage offers a balanced input with an impedance of 2x10K and a complete protection system. Several heat sinks allow to dissipate efficiently the heat released by the electronic components.
Compact, this amplifier of only 130x100x30mm for 350g makes it possible to design a compact, powerful and efficient audio system.
Product type | Amplifier module |
Amplifier type | Class D |
Power | 2x 200W @ 4Ω (THD < 1%) 2x 230W @ 4Ω (THD = 1%) 2x 115W @ 8Ω (THD < 0.1%) 2x 135W @ 8Ω (THD = 1%) |
Gain | 18.85 dB |
Input sensitivity | 1.5V RMS @ 200W 4Ω |
Input impedance | 20K Ohm |
Damping factor | > 320 |
Linearity | 1.3dB from 24Hz to 18kHz 3dB drom 16Hz to 22kHz |
Protections | Over currents Over voltages Under voltages Thermal protection DC speaker protection |
Amplifier efficiency | > 94% @ 4Ω > 96% @ 8Ω |
SMPS Power supply efficiency | > 93.5% @ 50% load |
Global efficiency | 88% @ 4Ω 90% @ 8Ω |
Supply voltage | 230V (210-245V) |
Dimensions | 130 x 100 x 30mm |
Mouting holes spacing | 122 x 92mm |
Weight | 365g |
Package | 1x IRS2200SMPS 1x 3 PIN to bare wire cable 20cm 1x 4 PIN to bare wire cable 20cm 1x 9 PIN cable to bare wire 15cm |
Input | PCB Connector |
Output | PCB Connector |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Infineon IRS2092 |
Power (W) | 200.0 |
