HYPEX FUSIONAMP FA252 Plate NCore Amplifier 2x250W DSP ADAU1450 DAC AK4454 192kHz
10%
The Hypex FusionAMP FA252 amplifier will allow you to design a subwoofer or a two-way active speaker. It is based on two NCore modules capable of developing no less than 2x250W RMS. The two modules can also be bridged to form a 500W mono amplifier. This high power allows the FA252 to accompany loudspeakers that need a lot of energy to reveal their potential.
Reduced price!
Reference : 16206
Limited time offer:
569,00 €tax incl.
-10%
512,10 €tax incl.
426,75 € tax excl.
Shipping date: 16-07-2025.
Hypex FusionAMP FA252 Amplificateur NCore Plaque 2x250W DSP ADAU1450 DCC AK4454 192kHz
Connectivity & other features
The FA252 offers a balanced analog input and output in XLR 3-pole format, an AES3 input and output, a coaxial SPDIF input and output, a Toslink optical SPDIF input and an unbalanced RCA Stereo input. The XLR and AES outputs are directly connected to the XLR input for one and AES for the other, and thus allow you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capabilities of your source.
This FusionAMP FA252 integrates a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. This software offers many possibilities to adapt your amplifier to your needs, like the creation of custom filters.
The front panel of the amplifier displays a series of 4 status LEDs. The first one warns of a malfunction or the reaching of a limit, so as not to degrade the equipment.
  • Fixed green: Amplifier on
  • Flashing green : IR signal received
  • Flashing Green / Red: Signal interruptions
  • Slow green flashing: Mute mode (output muted)
  • Fixed red: DC error / Fatal error, amplifier off
  • Flashing once per second: High temperature, output limitation
  • Flashing twice a second: Maximum temperature exceeded, output cut off
The next 3 LEDs, green, simply display the custom profile selected and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will blink slowly.
1Balanced analog input / output
2Single-ended analog input
3Mini-USB connector for configuration
4Status LED
5AES digital input / output
6SPDIF Coaxial Input / Output
7Toslink Optical Input
Schéma de fonctionnement
Hypex FusionAMP FA252 Amplificateur NCore Plaque2x250W DSP ADAU1450 DCC AK4454 192kHz
Note: In order to protect your speakers, the DSP does not have a pre-configured crossover from the manufacturer. A crossover must therefore be set up and injected using the Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
Product typeAmplifier
Output power2x250W @ 4 Ohm / (Bridgeable to 1x400W)
2x200W @ 8 Ohm / (Bridgeable to 1x500W)
2x180W @ 8 Ohm
Inputs1x Balanced 3 poles XLR
1x AES
1x Single-ended stereo RCA
1x SPDIF Coaxial
1x Optical Toslink
Outputs1x 3 poles balanced XLR (direct ouput)
1x AES (direct output)
1x SPDIF Coaxial
DSPADAU1450
DACAK4454
ADCAK5554
SRCSRC4382 - Max sampling rates : 192kHz
Frequency response10Hz - 50kHz
SNR121dB
THD+N0.0015% (10Hz-20kHz @ 0.5x rates power output)
Dimensions315 x 135 x 55mm
Weight1kg
Package1x FusionAMP FA252
1x Speaker cables
Dimensions
Hypex FusionAMP FA501 Amplificateur NCore Plaque 1x500W DSP ADAU1450 DCC AK4454 192kHz
A315mm
B135mm
C55mm
D291mm
E111mm
InputAES/EBU
InputXLR
OutputAES/EBU
OutputCoaxial SPDIF
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipHypex Ncore
Power (W)250.0
Power (W)500.0
The Hypex FusionAMP FA252 amplifier will allow you to design a subwoofer or a two-way active speaker. It is based on two NCore modules capable of...
