By buying this product you get 78 loyalty points
NCore Amplifier Module BTL 2x500W + 100W 4 Ohm
The Hypex FusionAmp FA503 can be an excellent foundation for designing a powerful 2-way or 3-way speaker. It is indeed capable of delivering 2x500W RMS power at 4Ω using a pair of NCore amplifiers. It can also be bridged (BTL mode) to obtain a powerful 1000W RMS amplifier. An additional channel of 100W RMS allows to power a tweeter.
On the connection side, there is a balanced XLR input, an unbalanced RCA input, an AES input, a Coaxial SPDIF input and a Toslink Optical input on the front panel. Pass-Through outputs are available for XLR, AES and Coaxial. A Mini USB configuration interface is also present.
The FA503 also includes 15 biquad filters per amplifier, 3 predefined filter profiles, a source select button, a signal detection and auto power off function, and a complete protection system.
Product type | Amplifier module |
Power | 2x500W + 1x 100W RMS @ 4Ω 2x 350W + 1x 100W RMS @ 8Ω |
Inputs | 1x Balanced XLR 1x Single-ended RCA 1x AES 1x SPDIF Coaxial 1x Optical Toslink 1x Mini USB configuration port |
Pass-Through outputs | 1x Balanced XLR 1x AES 1x SPDIF Coaxial |
BTL | 1x 1000W |
Input selection | |
Auto shutdown | |
Signal detection |
Voltage supply | 100 - 240VAC ±10% |
Dimensions | 420 x 150 x 90mm |
Weight | 2880g |
Package | 1x Hypex FusionAmp FA503 Speaker connection cables |
Input | SPDIF |
Input | AES/EBU |
Input | XLR |
Input | Optical |
Input | RCA |
Output | Coaxial SPDIF |
Output | XLR |
Output | ACSS |
Channel | 2 (Stereo) |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 1000.0 |
Power (W) | 500.0 |
