Class D Stereo TPA3116 Bluetooth 5.0 2x50W 4Ω
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a high efficiency, higher than 92%, while offering a clear and detailed reproduction. It also integrates its own volume control allowing to easily adjust the volume level. The amplification chip is topped by a heat sink to efficiently evacuate the heat released. An additional supplied fan can also be connected to the module for further dissipation. The module also benefits from a complete protection circuit against overvoltage, undervoltage, overcurrent, overtemperature and short-circuit.
On the connectivity side, the input is made in Jack 3.5mm or via a connector XH2.54mm 3 pins. A Bluetooth 5.0 reception chip allows it to broadcast its music remotely from a smartphone or a tablet for example. The Bluetooth antenna can be remote for an easy integration in the box thanks to a U.FL connector (external antenna sold separately). The output to speakers is done using screw terminals.
1 | 9-24VDC power input |
2 | External fan connector |
3 | ON/OFF switch |
4 | Right channel speaker output |
5 | Left channel speaker output |
6 | Jack 3.5mm input |
7 | Analog audio input on XH 2.54mm 3 pins connector |
8 | U.FL connector for external Bluetooth antenna |
9 | Bluetooth antenna |
Product type | Amplifier module |
Amplification type | Class D |
Amplification chip | TPA3116 |
Inputs | Bluetooth 5.0 1* Jack 3.5mm 1* Analog audio input on XH 2.54mm 3 pins connector |
Outputs | Screw speaker terminals |
Additional connectors | 1* 2 pins XH2.54mm fan connector 1* U.FL connector for external Bluetooth antenna (sold separately) |
Output power | 2*50W @ 4Ω, 1% THD+N 2*33W @ 8Ω, 1% THD+N |
Efficiency | > 92% |
THD+N | < 0.2% |
Gain | 32dB |
Protections | Short circuit Overcurrent Overheating Under voltage Over voltage |
Supply voltage | 9-24VDC via Jack DC 5.5/2.1mm (power supply sold separately) |
Total dimensions | 71.4*54*22mm |
Mounting holes spacing | 36*47.6mm |
Package | 1* Amplifier module 1* XH2.54mm 3 pins cable 1* Fan |
Input | XH 2.54mm |
Input | Bluetooth |
Input | Jack 3.5mm |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3116 |
Power (W) | 50.0 |
