Très déçu au niveau de la puissance
Mono Class D IRS2092S 200W 4Ω
This compact mono amplifier module is capable of developing a comfortable power of 200W, thanks to the use of two IRS2092S chips, with a high efficiency of over 90% and a gain of +31dB. The whole circuit takes advantage of quality components, allowing to reach a low level of distortion for a musical and dynamic restitution. A large heat sink allows to dissipate efficiently the heat generated by the amplification chips. The power supply is in +/-50VDC.
Product type | Mono amplifier module |
Input | 1x Analog input on screw terminal |
Output | 1x Analog output on screw terminal |
Output power | 200W |
Efficiency | ≥90% |
SNR | 90dB |
THD | ≤ 0.05% @ 250W, 4Ω |
Frequency response | 20Hz - 20kHz |
Recommended speaker impedance | 4-8Ω |
Supply voltage | +/-50VDC on screw terminal (not included) |
Dimensions | 86 x 56 x 29mm |
Weight | 100g |
Input | Screw terminals |
Output | Screw terminals |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Infineon IRS2092 |
Power (W) | 200.0 |
Average votes 2.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
