This kit is designed for professionals and DIY enthusiasts alike. It includes a volume knob, a moisture-resistant LED, a 2.4GHz antenna and a TSA2210U amplifier board and Bluetooth receiver. Users can adjust the volume of the Bluetooth audio either via their smartphone, or using the supplied knob. The kit can be powered by a 12VDC power supply or a 12V battery. The LED can indicate ON/OFF status and battery voltage. The kit can be installed in a box to easily create your own audio amplifier.
The TSA2210U Class D amplifier board is based on a TPA3110D2 amplifier chip to develop 2x8W power at 8Ω. It can be powered by any DC 8-16V supply and will be able to drive any 4Ω or 8Ω passive loudspeaker. The volume control circuit is also integrated on this board. The Bluetooth 4.0 receiver uses a CSR8635 chip.
Product type | Amplifier board Bluetooth receiver |
Amplification chip | Qualcomm TPA3110D2 |
Bluetooth chip | CSR8635 |
Input | Bluetooth 4.0 |
Output | Screw terminals |
Quiescent current | 20mA @ Vcc=12V |
Input sensitivity | 0.283V @ gain=26dB |
Input impedance | 30kΩ |
Gain | 26dB |
Output power | 8WRMS @ Vcc=12V, THD+N=10% |
Efficiency | 86% |
Frequency response | 20Hz - 22kHz (+/-3dB) |
Supply voltage | 10.3-16VDC (power supply not included) |
Amplification board dimensions | 80*49mm |
Amplification board mounting holes spacing | 70*40mm |
Knob board dimensions | 50*26mm |
Knob board mounting holes spacing | 40*16mm |
Input | Bluetooth |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3110D2 |
Power (W) | 8.0 |
