WONDOM AA-AB31282 Mono Amplifier Module Class D T-Amp 1x200W 3 Ohm
The Wondom AA-AB31282 amplifier is capable of delivering 1x200W of mono power under 3 Ohm. This substantial power reserve allows this amplifier to be associated with demanding speakers or subwoofers, requiring a significant power input. In addition, the module supports BTL (Bridge-Tied Load) configurations and is therefore bridgeable to provide power boost.
Reference : 13101
39,90 €tax incl.
33,25 € tax excl.
WONDOM AA-AB31282
Mono amplifier module Class D 1x200W T-Amp PBTL
Wondom AB31282 module amplificateur mono class d t-amp 200w 3 ohm
A compact but really complete module
The module also benefits from the brand's T-Amp technology. This ensures a lower distortion and a lower noise level. In order to dissipate heat, a radiator is placed on the heat releasing components.
Electrical characteristics
ParameterConditionsMin.Typ.Max.Unit
Power supply-153436VDC
Efficiency200W @ 3 Ohm85-93%
Minimum impedance--2-Ohm
Switching frequency--660-kHz
Fan activation temperature--50-°C
Caractéristiques audio
ParametreConditionsMin.Typ.Max.Unit
Gain--26-dB
Input sensitivity (RMS)--1.31.8V
Input impedance--1011kOhm
Output power@ 3Ohm THD+N 1%-150-W
@ 3 Ohm THD+N 10%-200-W
Frequency response @ +/-3dB@ 3 Ohm20-20kHz
THD@ 3 Ohm 1W 1kHz-0.00510.1%
@ 3 Ohm 100W 1 kHz-0.0690.1%
Output noise levelA-Weighting, input connected to GND-129300µV
SNR150W @ 3Ohm THD+N 1%-96101dB
Performances graphs
OutputScrew terminals
Channel1 (Mono)
Amplifier chipN/A
Power (W)200.0
Parfait!
Alimenté sur batterie en 32v cet ampli tient ses promesses: sur un sub de 8" il sait donner de la voie sans que la distortion se fasse entendre. L'efficacité semble être au rendez vous: il chauffe peu et les batteries durent plus longtemps que ce que j’avais calculé. A recommander!
This review has been posted for WONDOM AA-AB31282 Mono Amplifier Module Class D T-Amp 1x200W 3 Ohm
The Wondom AA-AB31282 amplifier is capable of delivering 1x200W of mono power under 3 Ohm. This substantial power reserve allows this amplifier to...
