Class D Mono Amplifier Module TPA3118 40W 4 Ohm
The Wondom AA-AB31521 is a small, simple and efficient Class D mono amplifier module. It includes a TPA3118 TI chip to enable it to provide a power of 40W at 4 Ohm for an efficiency of 90%, as well as a precise sound reproduction. In addition, the module has very good heat dissipation, eliminating the need for a heat sink and ensuring long durability. The circuit is also protected by a series of overload, high temperature and reverse polarity protection.
| Specifications | |
| Product type | Amplifier module |
| Amplifier chip | TPA3118 |
| Channels | Mono (1) |
| Power | 1x40W |
| Parallel Bridge Tied Load mode support | Yes |
| Input | 1x RCA |
| Output | 1x Speaker screw terminal |
| Supply voltage | 10V-24V DC via Jack DC 5.5/2.5mm |
| Protections | Overload, thermal protection, inverted polarity |
| Measurements | ||||
| Parameter | Conditions | Min | Typ | Max |
| Power | @ 4Ω THD+N 1% | - | 31W | - |
| @ 4Ω THD+N 10% | - | 40W | - | |
| Gain | - | 24dB | 25dB | 26dB |
| Input sensitivity(RMS) | @ 4Ω, 40W, 1kHz | - | 730mV | - |
| Input impedance | - | - | 47kΩ | - |
| Frequency response @ ±3dB | @ 4Ω | 20Hz | - | 20kHz |
| THD | @ 4Ω, 1W, 1kHz | - | 0.0117% | - |
| Output noise level | - | 83.24µV | - | - |
| SNR | 31W @ 4Ω THD+N 1% | - | 99dB | - |
| Supply voltage | - | 10V | 19V | 24V |
| Max current | 40W @ 4Ω | - | 2.5A | - |
| Efficiency | 40W @ 4Ω | 82% | - | 87% |
| Switching frequency | - | - | 320kHz | - |
| General | |
| Dimensions | 91.44 x 68.58 x 16.5mm |
| Weight | 156g |
| Input | RCA |
| Output | Speaker terminal |
| Channel | 1 (Mono) |
| Class | Class D / T |
| Amplifier chip | T-Amp |
| Power (W) | 40.0 |
